Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 04-20-2006, 02:22 PM
ENCEE ENCEE is offline
97' Alternator Replacement Help!!!!
Hello everybody, i need to replace my alternator on my 97 expedition
to start this is very different from other vehicles, first question how
do i release tension on the belt and when i do how do i know how much
pressure it needs back......any help thanks....
Old 04-20-2006, 02:30 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 97' Alternator Replacement Hep!!!!
The belt has a tensioner that keeps the proper amount of tension on the belt. It will be an aluminum piece that has a black pulley on it. Look close to the pulley and there may be a square hole that is used to pull the tensioner back. It is point B in the picture.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-20-2006, 03:37 PM
I DID LOCATE THE PULLEY. WHAT DO I DO NEXT.,,,ITS MY FIRST TIME DOING THIS ...THANKS :
DO I UNCREW OR JUST PULL????
Old 04-20-2006, 05:37 PM
way2old's Avatar
TOKEN HILLBILLY
Put a ratchet in it and push in the direction of the broken arrow. Be sure to disconnect the battery negative cable first. Then remove the belt, remove the connections and unbolt the alternator.
Old 04-20-2006, 06:08 PM
THANK YOU...THANK YOU...MAKE A LOS SENCE NOW...
