Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-20-2006, 03:08 PM   #1
mikmic2
Fluctuating Idle with Rotten Egg smell.
I've got a 1992 Cutlass Ciera with a 3100. It idles up and down just like you would expect with a vacuum leak. However, I can't seem to find any leaks. I've checked the vacuum booster, and just about every other line I could see, but they aren't leakig. It also has a moderate Rotten egg smell. I thought of the Catalytic Converter, but it runs good going down the road.
Anybody have any similiar experience, or have a clue what it might be?
I thought maybe the EGR valve. Does that sound possible?
Any other ideas?
mikmic2 is offline   Reply With Quote
Old 04-20-2006, 08:59 PM   #2
s10blazerman4x4
s10blazerman4x4's Avatar
Send a message via AIM to s10blazerman4x4
Re: Fluctuating Idle with Rotten Egg smell.
From my experiences last few weeks in my cutlass calais 2.5 it was two things: O2 sensor and that should throw a code and the catalytic converter went out along with an exhaust leak at the manifold. Take in mind i got FWD but check everything for leaks and check for codes.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
s10blazerman4x4 is offline   Reply With Quote
Old 04-25-2006, 08:14 AM   #3
Slade901
Banned
Slade901's Avatar
If the IDLE goes up and down by itself, it sounds like a bad TPS (Throttle Position Sensor) going bad. I would also try to clean the IAC (Idle Air Control solenoid). They are all located on the Throttle body. It might be a good time to remove the egr and it's pipe and clean it as it maybe clogged up with hardened carbon.
Slade901 is offline   Reply With Quote
