Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-20-2006, 01:19 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Intercooler and Front Crankshaft Seal question
Two completely unrelated topics in one thread
I'll start with the front crankshaft seal. It's leaking. I figure I'll just do a full timing belt job (inc. water pump) since I'll be in the area. I haven't done a t-belt since I got the car at 119k and I'm pretty sure I'm pressing my luck at this point. I'm also going to be loading on the mods come mid-May (see sig list) and I swore the oath on the MachV website . I'm going to be ordering this part
http://www.rockauto.com/catalog/cata...IengineID=2327
Is there anything special I should watch out for when changing it? I've never seen the area and I don't know what I'm dealing with yet but I want to be armed with some knowledge.
As far is intercoolers go, I know a lot of people do the intercoolers that have the inlet/outlet on opposite sides of the core, but I was thinking of going with this one:
http://cgi.ebay.com/ebaymotors/GODSP...58235439QQrdZ1
Is it easier to run the pipes if they are both on the same side of the IC? Having never seen a FMIC pipe routing outside of pictures, I was hoping someone that's done a FMIC could give some insight. I just don't know how it all would fit in and what kind of cutting would be required.
Here's the plan. I have a stock 1g J-pipe coming off my turbo that has a 1.5" or 2" opening (I'll measure when I get home from work because I don't know offhand). I figure I can run a 2" to 3" coupler and pipe it to the top inlet on the IC. Then for the outlet, I want to use my existing dejon UICP so I can keep the type-s flange. I'd get rid of the braided "S" stock portion of the UICP and couple the dejon pipe directly to the TB elbow. Then I'd run 3" piping from the outlet of the IC up to the end of the dejon pipe. Again, having never done anything like this before and not looking at the car right now, I'd like some input as to whether it is feasible or not to run the pipes like I hope. I know I'll be jumping between 2" and 3" and 2.5" but I'm not planning on making 500hp so I think that it will flow well enough.
Let me know what you think. Thanks guys.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 04-27-2006, 04:31 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Intercooler and Front Crankshaft Seal question
The front crank seal is in the oil pump cover. If it's on the outside of the cover you just have to pop out the old one with a pick of some sort without damaging the bore in the cover or the crank, and drive the new one in squarely. If it's on the inside of the cover, this becomes a whole different game. Wish I could remember where it was, maybe someone has an oil pump closer than 45 minutes away that they could reference. Or you can look up some pics.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-27-2006, 09:37 AM
From what I've read on Tuners and searching here, it's an easy job when you are doing the t-belt so I'd guess it would be on the outside. Thanks Kevin, I'll be cognizant of the bore and crank when changing it.
Old 04-27-2006, 10:05 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Yeah, it's on the outside and should be a breeze if you're also doing a t-belt.
95 Talon TSI AWD
97 Eclipse GST
Old 04-27-2006, 12:44 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Cognizant, I think thats what I was drinking last night. Seriously, what does that mean?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-27-2006, 01:56 PM
Aware, conscious. Thanks for the good news
Old 04-27-2006, 02:44 PM
Where did that come from? I'm lost.
95 Talon TSI AWD
97 Eclipse GST
Old 06-25-2006, 11:31 PM
Fallenfantasies Fallenfantasies is offline
yeah that should do it
Old 06-25-2006, 11:48 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
You really need to not bring back anymore old threads...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
