Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-20-2006, 12:17 PM
LoudLowNslow LoudLowNslow is offline
MORE starter problems, car might be junk, help!!
So i hooked up my starter wrong, im an idiot. i turned the key to see if it worked, and i heard a "pop", like a fuse blew or something, and the dash lights went off. i disconnected the battery, and hooked the starter up correctly, then reconnected the battert. Now the ONLY power i get through the car is my headlights,taillights,horn, and if i hit the brakes those lights come on. NOTHING else electrical in the car works, wether i turn the key forward or back. what could it be????PLEASE help me!!!!
Old 04-20-2006, 01:55 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: MORE starter problems, car might be junk, help!!
sounds like you shorted something out, what that something is i have no clue
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-20-2006, 02:07 PM
JunkyardLife JunkyardLife is offline
Dont panic..Pull your fuse panel off and check all your fuses closely. If theres no problems there, check all your wiring. Especially grounds.. Theres also a fuse on the passenger side fenderwall.
Youll find it.
Old 04-20-2006, 02:13 PM
All the fuses on the inside of the car are good, and under the hood theres that other fuse box with big fuses in it and all those are good too..i hope its not anything too bad, i REALLY want to get this car on the road!
Old 04-20-2006, 03:14 PM
GreyGoose006 GreyGoose006 is offline
You'd really have to screw up to render a car usless after messing up the wiring. you may want to check the computer tho. if it is an older caprice w/ a carb, you can disconnect the computer and try to run it that way if the computer is bad, otherwise, im guessing you blew a fuse, or burnt up a wire that you dont see.
Old 04-20-2006, 03:48 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
There is a fusible link on a wire near the starter - this is a smaller gauge wire than normal and it has a special insulation on it. The fusible link is designed to blow if something shorts out, to prevent a fire. Look for blistered insulation on a wire - that will be a fusible link that's blown.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-20-2006, 08:41 PM
Blue Bowtie's Avatar
Registered Offender
Actually, I think there a three fusible links there.
Old 04-21-2006, 07:57 AM
Just a thought...When you try to crank the engine with your lights on - do the lights turn off? If they do, then theres just a loose cable/connection somewhere.
Good luck
Old 04-21-2006, 09:50 AM
its not an older caprice, its a 95 9c1 with the lt1. The lights dont do anything when i try to crank it, because when i turn the key, nothing happens at all...and when i turn the key to accesories, nothing turns on(radio and all that), where would i find this inline fuse thing that was spoken of??
Old 04-21-2006, 10:13 AM
Registered Offender
Look in the UEC (Underhood Electrical Center) along the right rear corner of the engine compartment. There are a couple of MAXI fuses there that protect the main power wiring. And if you haven't already done so, you might want to replace the cast zinc main power stud there with the phosphor/bronze upgrade part to prevent further trouble.
