Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-20-2006, 11:56 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Nitrous... help!
Ok, so this guy that I may be buying the cams from also has a 4 port nitrous system with 75 shot jets, solenoids, lines, an nozzles for $150. What else would I need? Just a bottle right? Bigger injectors to compensate for fuel? What would be good mods to support it? SS valves right? Would the stock pistons take it? If any one can shed some light on the whole nitrous thing, I'd appreciate it, its on thing I dont know much about.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-20-2006, 01:57 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Nitrous... help!
This is what I think about nitrous I say if you're not to the point where you need it, you probably shouldn't be running it.
If you're really serious about running it pretty often, then replacing valves and pistons are a must and you might as well just go with a full build then. It's a direct port system right?
95 Talon TSI AWD
97 Eclipse GST
Old 04-20-2006, 05:36 PM
Thor06's Avatar
Jizzed In My Pants
Yup. I for sure wouldnt use it often, just at the track and the occasional run on the street (but for sure never on pump gas). I wouldnt actually finish out the kit and put it in until I get farther down the line (FMIC, 255, fpr, bigger injectors, exhaust, DSMlink) but its sure cheap enough. Are new pistons/valves necessary for occasional track use?
Old 04-20-2006, 07:49 PM
I wouldn't say they are necessary, but I would definitely want them, especially for use at the track when you'll be running the car hard the way it is, and then adding nitrous on top of that.
95 Talon TSI AWD
97 Eclipse GST
