Old 04-20-2006, 12:48 PM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
I have a kinda VERY big problem
i cant turn my car off! I fought with my keys for about 10 mins trying to turn it back to the lock position. No success so i pulled the ignition fuse and unhooked the battery. It got stuck last night, but i turned it forward (and made that loud noise) then turned it off. that didnt work this time. anyone know the deal?
car audio guru...
Old 04-20-2006, 12:51 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: I have a kinda VERY big problem
Bum lock cylinder or actuating rod to the ignition switch could be binding up or bent.
Old 04-20-2006, 12:54 PM
can i get to it with the tools i have access to....? screwdriver and pliers...
car audio guru...
Old 04-20-2006, 01:19 PM
wrightz28's Avatar
Never really messed with 4th gen column, somebody else will have to chime that, however remember 2 words: airbag disarmerment
Old 04-20-2006, 02:32 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
lol... that would be a good thing to do
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-20-2006, 03:49 PM
kahjdh's Avatar
kahjdh kahjdh is offline
lmao, that could kill ya, definantly disconnect the battery.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 04-20-2006, 03:53 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Stone Mound was Found Dead This Morning, Murdered by his Own Airbag, and Parked...*stops reading* who wrote this??
Old 04-20-2006, 08:18 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
with the car still running...lol
ever get the key out guy? If you car is an auto then maybe it has something to do with the shifter lock...
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 04-20-2006, 08:21 PM
btw that "loud" noise that happens when you turn the key is your starter motor grinding its teeth against the flywheel teeth....very bad.....dont do that....
Old 04-20-2006, 08:24 PM
i practically had to get pliers to pull out the key.its out and i have been told it is ignition switch. can i jus go up to Autozone and get a new one or do i gotta see a dealership because of VATS
car audio guru...
Old 04-20-2006, 08:44 PM
goldz28's Avatar
goldz28 goldz28 is offline
That is probably a dealer item.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 04-20-2006, 10:42 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
just by-pass the vats and then you are ok.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 04-21-2006, 01:35 AM
Dyno247365's Avatar
Okay pretend i dunno nothing, what are VATS?
Old 04-21-2006, 01:46 AM
Vehicle Anti Theft System.... the reason for the chip in the key
car audio guru...
Old 04-21-2006, 02:45 AM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
man that airbag stuff is no joke. Anytime we have to go underneath the dash on an airbagged car we have to wear ear protection. I have a set that looks like the guys at airports wear lol. But if it goes off while your under there, you WILL lose your hearing because it causes a negative pressure under there. Crazy stuff.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
