Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-20-2006, 10:48 AM
Johnnystorm Johnnystorm is offline
Send a message via AIM to Johnnystorm Send a message via MSN to Johnnystorm Send a message via Yahoo to Johnnystorm
1995 Aurora will not start
Hi all:
Here is my problem at first it would just take a few seconds to start when i turn the ignition and after a while it took like 10 seconds to start and finally it just will not crank up and i mean not even turn over so i had the starter replace and he changed it out and it still didn't crank up so now i am like what is the problem any help please
Old 04-20-2006, 03:56 PM
ghutchin ghutchin is offline
Re: 1995 Aurora will not start
If it won't turn over it could be your ignition switch or anything in between that and the starter like the wires. Your battery could also be dead, I assume you tried jumping it though.
Old 04-20-2006, 09:38 PM
apollo7879 apollo7879 is offline
Is the starter solenoid clicking each time you try to start it?
If you have intermittant starting even after you have changed the starter,
You more than likely have a poor ground connection. Check & clean your ground connections.
