Old 04-20-2006, 09:28 AM
Stites Stites is offline
Unhappy '96 Windstar trans leak
Hey y'all. New here and new to minivans. Our Windstar's transaxle deeloped a serious leak and grabbing/slippage issues with my wife a couple days ago. We managed to get it home about 25 miles at a time by way of LOTS of ATF, and intended to fix it the next day. Welp, the leak stopped yesterday . We put a new filter/screen in the transaxle, and it drove better, but the leak came back and the O/D light started flashing after a good run around town to check things out.
I have a front seal ready to go in this thing... just a matter of getting to it. I'd like to know what the best way is to get to the old seal... yank the engine, drop the trans, what do y'all suggest???
Thanks a LOT in advance.
98% of fatal car crashes in the southern Appalachians begin with "Hey y'all, watch this!"
Old 04-20-2006, 11:55 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: '96 Windstar trans leak
Hello
I would drop the trannie to replace a seal inbetween the converter and trannie. I would check on the spider gears coming out of place if a retainer isn't put in and follow driveshaft removal removal order listed in a manual.
I take it that you see fluid leaking from here? Before going to all this work, I would check the servo cover that has the heat shield by the converter that was posted about a few days ago to see if that is leaking. I know you didn't get an answer to that post....but I would hate to pull a trannie and find out that the front seal wasn't the problem.
I just replaced the trannie in my 97 LeSabre. If you have questions feel free to contact me. Happy to help. I've been Found On Road Dead with a Ford.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 04-20-2006, 01:04 PM
Dan, I appreciate the help. I did the servo thing, all is well and dandy in it. There's no evidence of any kind of leak anywhere except for a small drop hanging from the bellhousing dust cover, which leads me to think either a bad seal or a torque converter problem.
If the seal was cracked, it'd leak all the time, right??? If it's just old, I may pour some snake oil in it to get it going for now, and once money comes in from what my wife does with the van(medical transport), we may slap another trans in it altogether.
Hopefully, this won't be one we have to Fix Or Repair Daily.
Old 04-20-2006, 06:48 PM
Welp, so far the snake oil has fixed the leak. But, whilst on the test drive, the O/D light started flashing again, and on into the drive, I lost all gears past 2nd... not that they don't work, just that it won't upshift into 3rd of 4th. Anywho, made it to Advance, and now we have codes to get us in the right direction of thinking:
0732 Gear 2 ratio incorrect
0733 Gear 3 ratio incorrect
0734 Gear 4 ratio incorrect
0741 Torque Converter CKT Performance or Stuck Off... WTF???
Any idea what kind of sensors there might be in question here???
Old 04-20-2006, 09:17 PM
Blue Bowtie's Avatar
Registered Offender
Check the neutral safety switch on top of the transmission. It reports data to the PCM, allowing the PCM to shift the trans. With no signal, you'll get no shifting. That is also called a Transmission Range Switch, Transmission Range Sensor, or TRS. Places that sell them as a "Transmission Range Sensor" (a.k.a. the dealership) ask about $90 for a replacement. Places that sell them as a "neutral safey switch" sell them for about $40.
If you want to test yours, read this thread:
http://www.automotiveforums.com/vbul...d.php?t=535091
Old 04-21-2006, 10:00 AM
My wife printed that thread out for me last night. Tried it this morning, and it did the same stuff as you described... firm upshifts, no O/D, no lockup(though it seemed like it was gonna a time or two), whole nine yards.
Advance will have a "neutral safety switch" in tomorrow... $32 should get this puppy back on the road.
Old 04-21-2006, 06:52 PM
wiswind wiswind is offline
Not going above 2nd gear is "Limp mode".
A numer of things can cause this......but right up at the top of the list....AND at the bottom of the COST list is that TRS, aka Neutral Safety switch.
Well worth the $32 shot.
Remove the Air filter/ MAF "tube" and the big flex hose from the air filter / MAF unit.....to the throttle body.
Then you will be able to look down and see the TRS right on top of the transmission.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 04-21-2006, 10:35 PM
Stites0518 Stites0518 is offline
Found it earlier this morning, thanks. There was another plug going into what looks to be behind the torque converter... would that be something dealing with the lockup clutch?
Old 04-24-2006, 12:32 PM
Unhappy Re: '96 Windstar trans leak
We changed the transmission Range Sensor last night. Today it won't shift out of 2nd gear and the RPMs shoot up to 3500 - 4000. Eric would put it in neutral and kill the engine then start it back up. Sometimes that made it better. The O/D light starts to flash when the shifting acts up. Sometimes it shifts like it's supposed to. Other times I have to slow it down to 40 mph to lessen the RPMs. I run a medical transport business and this is my only vehicle to use. The trans only has 40,000 miles on it and the dealer will not do anything about helping fix it. Anybody have more advice??? I'm losing a lot of money each day by not using my van. Thanks!!
Old 04-24-2006, 03:44 PM
joeuser742 joeuser742 is offline
You are probably low on fluid. Most likely the reason it 1st started dumping fluid is because the fluid was getting too hot (old and broken down). I'd say that you need a transmission flush. I'll have to double check, I have a 99 and that safety valve is behind the torque converter. Between that and changing the filter and TRS should fix your leak and shifting problems. My trans would dump the fluid when I was on the highway, then would stop when it cooled down.
Another thought is the (VSS) speed sensor.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 04-25-2006, 07:48 AM
VSS was the next thing on the list. I now have a Haynes manual that tells a little bit of the sensors, switches, and whatnots that can cause wierd transaxle operation.
The turbine shaft speed sensor(TSS)... could that be a possibility, and how hard is it to change???
Old 04-25-2006, 11:32 AM
Registered Offender
The connector on top of the transmission is for the valve body solenoids and a couple sensors. The transmission is electrically monitored and shifted by the PCM. You can remove that plug from the transmission, inspect both the plug and connector on the trans for corrosion, moisture, contamination, or other damage. Clean everything, apply silicone dielectric grease to the pins and the seal, and reinstall the plug.
As for the "Transmission Range Switch" itself (or "neutral safety switch" or "Manual Lever Position Sensor" as ATSG calls it), it not only has to be installed and working, but needs to be positioned correctly. You should have noticed some phase or position indicator marks on the switch. The switch can be adjusted slightly to assure it's in the correct position when the manual lever is in a given range. There is also a pin gauge that can be inserted into the switch to hold the "home" position while tightening the mounting screws so that the adjustment is correct.
If you suspect a different problem with the transmisison, you can "test" the transmission in a default mode with an easy procedure. Start the vehicle, warm the transmission to operating temperature, then disconnect the Transmission Range Switch (TRS). Take the vehicle for a short drive. The "OD" indicator on the end of the gear selector lever should be flashing since the PCM won't have a clue what is going on. The shifts should be noticably harsher since the trans is probably operating at full line pressure - no active PWM solenoid to modulate pressures.) It should not go to OD, and of course the TCC shouldn't lock, but with the PCM running "blind", that's to be expected.
If the transmission shifts 1-2-3 normally with the TRS disconnected, the problem is likely with the adjustment or connections of the TRS. If you still experience problems shifting 1-2-3, there may be another problem within the trans.
The TSS is accessible (but barely) from the outside of the trans, just above the left half shaft and rear of the side cover of the trans. You'll need to be a contortionist to diagnose the sensor. Unplug the sensor and measure the resistance. It should be between 80-220 ohms. If the reading is out of range, reverse the polarity of the meter's test leads and check it again. If the resistance test is good, remove the sensor and get a good flashlight and mirror. Look inside the mounting hole, and slowly rotate the engine until you can see a tooth on the wheel inside the hole. Measure the depth of the tooth from the outer edge of the cover. It should be no greater than 20mm. If the trigger tooth is present and doesn't exceed the correct maximum depth, clean the TSS sensor face and reinstall it.
Old 04-25-2006, 12:32 PM
Registered Offender
This may help:
Old 04-25-2006, 09:35 PM
Hey, thanks for that diagram, BlueBowtie. I've pulled the low/int servo, and all is well. TRS is new now, probably needs dialed in, though. You're right about the TSS... that'd be a pain in the @$$ to replace. If possible/safe, I may look at the O/D servo. Definitely gonna check the VSS.
Once we cover bills and all, we'll probably put another trans in it and drive on with our bad selves.
Old 04-26-2006, 09:33 PM
Nuther question... what year models have the same transaxle as the 96? I believe we have the AX4S, even though it says AXOD on the pan. Also, is there any year that would be more desireable over another???
