Old 04-20-2006, 07:47 AM
BDeckert BDeckert is offline
Speaker Replacement/Removing the door panel
1998 Blazer
Need to remove the door panels......
Im working on my stereo and need to get to the speakers in the doors, but im not sure how to get the panels off and dont want to just rip em off. Any help?
Old 04-20-2006, 09:40 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Speaker Replacement/Removing the door panel
Two small bolts under the door arm rest and have to remove the 1 phillips screw on the plastic behind the small opener handle. Then grab the bottom and pull out cause plastic push in pins hold the panel on. The switch control panel can be pushed to rear and it unclips and will fit thru the opening in the door panel. Lift off the panel from the top window lip and you are done. When you reinstall make sure the pins all line up and snap in, especially the front one by the light switch half way down - if its not in the switch may break off when you close the door (see the little raised strike plate on the door panel it hits)
