Go Back   Automotive Forums Car Chat > Toyota > Solara
Old 04-20-2006, 01:02 AM
merrell merrell is offline
chutch help
i am installing a clutch in a 99 solara wll is done just need to bolt everything back up but the trans will not slide back in (in being into the crank spindal) im hopeing that there is a trick thanks
Old 04-23-2006, 05:24 AM
KimMG KimMG is offline
AF - Advisor
Re: chutch help
Before installing the clutch disk, did you test the fit on the transmission. Did you test fit the pilot bearing? Did you use a good clutch alignment tool?
