Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 04-19-2006, 11:38 PM
suprasizeit suprasizeit is offline
Angry Help Asap!
one of my coolant hoses busted and poored right into my sparkplugs! I changed the plugs and dryed it best i can but now it wont stay running and theres popping and smoke coming from the plug area. could it be that i need to dry it more change the plug wires or what help me out soon.
Old 04-20-2006, 12:23 AM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: Help Asap!
What do you mean by "dried it the best I can." That sounds to me like you didn't do a very good job. You should have gotten every bit of coolant out before removing any of the plugs. You don't want to get any coolant into the cyl.
Did you properly tighten the plugs? The poping may be compression escaping the cyl.
If the poping is electrical then pull it apart and inspect the plugs and wires for damage.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 04-21-2006, 01:00 PM
Re: Help Asap!
yeah i took everything apart and dried it out and heat dried it for like 4 hours. Like i said i changed and replaced everything brand new except the sparkplug wires and i had to special order them because nobody had them in stock. If it still does it after the wire change then i got bigger problems
