Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-19-2006, 10:50 PM
sau4u sau4u is offline
Idle problems
1994 mustang, standard transmission, 3.8l v6. Usually idles around 5000 rpm. Seems kinda low and trying to teach my son how to drive a stick he is having trouble starting out that low. I set up the idle screw by the accelerator cable, extremly hard to adjust. Goes right up to 11000 and wont go any lower. Also seems like over a couple of days the idle is back down around the 5000 rpm again but the screw has not turned back (I marked it to watch). Is there another way to adjust the idle or a second part to what I am doing. Thanks.
Old 04-20-2006, 12:32 AM
vitali9999 vitali9999 is offline
Re: Idle problems
K this is not enswer to your question since i have idle problems of my own on my car but man you must be driving an F1 car to have idle at 5000-11000 RPM but im sure u ment 500-1100RPM
Old 04-25-2006, 01:11 PM
95MustangGTC 95MustangGTC is offline
Re: Idle problems
Check or clean your Idle Air Control. its close or on top of your Throttle plate. Take it off and clean it out with Carb cleaner. There should also be an allen headed nut close to it that you can adjust the idle.
Old 05-13-2006, 11:12 AM
fordforlife's Avatar
fordforlife fordforlife is offline
Re: Idle problems
when you adjust the idle, unplug he IAC first, adjust the idle with the screw he's talking about, then plug it back in.
Old 07-29-2006, 10:06 PM
N2TRUKN N2TRUKN is offline
Re: Idle problems
Yea, The Screw On The Cable Is Just For Tention On Cable. Turn It Back To Wher You Found It. But I Think The Idle Should Be About 6-700 Rpms. Just Have Your Kid Rave Up A Little Higher Than Normal. After Awhile He'll Get The Feel And Be Doing Just Fine. However The Computer Is Probaly Tring To Compensate For The Flap On The Other Side Of That Cam The Cables On. The Cable Really Just Lets More Air In. The Fuel Is Controled By The Senser The Othe Guy Was Talking About. Good Luck
