Old 04-19-2006, 10:32 PM
max3456's Avatar
max3456 max3456 is offline
Send a message via Skype™ to max3456
Question fuel filter change
Are any special tools needed to replace the fuel filter on a 04 TB? How are the fuel lines connected? Quick connectors? Any suggestions on fuel filters?
Thanks for your help.
Darrell
2006 HHR LT 2WD Metallic Blue
Ecotec L-2.4 175 HP
4-spd Auto
Old 04-20-2006, 05:23 AM
rodeo02 rodeo02 is offline
Re: fuel filter change
I've heard that you have to drop the tank skid plate for clearance. No biggie from what I hear. Just normal clamps for the filter. My 2005 has the filter in the tank.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 04-21-2006, 10:56 AM
KGaugh1805's Avatar
KGaugh1805 KGaugh1805 is offline
Send a message via AIM to KGaugh1805
Have you changed your filter on the '05 yet? I have same here and interested in knowing where and how easy it is to do so?
Old 04-21-2006, 11:20 AM
There's no fuel filter to change on the 2005+ TB's (as far as I know). It's inside the tank. Someone posted a pic of a typical cannister looking filter, but I don't see how that's possible for an in-tank filter. In-tankers are almost always a big sock on the pump suction. You can replace the sock on a pump changeout.
Joel
Old 04-25-2006, 10:40 PM
dmince dmince is offline
The filter on my '02 is located inside the frame rail on the drivers side. Small clamp with a very rusted screw hold it on. You can change it with a pair of needle nose. Be carefull with the plastic clips though.
Old 05-05-2006, 10:06 AM
max3456's Avatar
I recently changed the fuel filter on my 04 and it was very easy. One screw and the two fuel line clips. It is mounted on a frame support just in front of the fuel tank. $22.00.
Darrell
Ecotec L-2.4 175 HP
4-spd Auto
Old 10-10-2006, 12:49 PM
coolcloo1019 coolcloo1019 is offline
On my old car, when changing the fuel filter, I used to take out the fuel filter fuse, crank over the engine a few times to get all the fuel and pressure out of the lines and THEN disconnect the lines on the filter so I didn't get sprayed. Should I do the same thing on the Trailblazer? Thanks guys.
Old 10-10-2006, 04:47 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: fuel filter change
Pretty old thread here, but anyway there is a pressure bleed off valve next to the fuel filter.
Old 10-12-2006, 01:06 PM
Blue Bowtie's Avatar
Registered Offender
What is the standing fuel pressure supposed to be on those? I know the '05 models have pressure controlled via in tank FMU and not a remote FPR, but the '04s are just the plain old, supply/regulator/return line system.
Old 10-12-2006, 04:05 PM
A990 racer
Red face Re: fuel filter change
I am driving a 2002 and don't know the fp specs, some mod huh!!?? I believe it is 55-60.
Old 10-14-2006, 09:47 PM
Registered Offender
That's probably right. I've got one (2004) at 56-57 PSIG rock steady. It has the typical "no power in second gear" problem. Time for a reflash, I'm thinking.
Old 10-14-2006, 10:21 PM
..I know the '05 models have pressure controlled via in tank FMU and not a remote FPR, but the '04s are just the plain old, supply/regulator/return line system.
Good info! I was wondering why I could not locate a FPR on the fuel rail of my 2005. There's only a shraeder valve about where the FPR *used* to be. Interesting. What is FMU?
Thanks
Joel
Old 10-15-2006, 02:26 PM
A990 racer
Thanks
Joel
Pump voltage is increased /deceased on demand by the pcm based on engine load, the system is returnless and of course no regulator, no inline filter either.Actually I believe the pump is pulse width modulated by the pcm rather than actual voltage changes to the pump, I will look into that. FMU, Fuel Management Unit.
Old 10-15-2006, 10:16 PM
Originally Posted by maxwedge
..I believe the pump is pulse width modulated by the pcm rather than actual voltage changes to the pump, I will look into that. FMU, Fuel Management Unit.
I guess the good thing is less plumbing, bad thing is anything with "management unit" in it sounds expensive !
Thanks
Joel
Old 10-16-2006, 09:26 PM
16th hippy 16th hippy is offline
it is expensive....that "little black box" is one of the more expensive parts of a "modern" car. EBCM's(Electronic Brake Control Module) are worse. did one on a Tahoe the other day, over $900, JUST FOR THE PART!
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
