Old 04-19-2006, 09:54 PM
Camaro84 Camaro84 is offline
Car actin real dumb
my 84 maro wont start and im getting back fire threw the carb...... cleaned spark plugs and there is fuel..........
it was just running yesterday and now it doesnt want to start....
the only thing i can remmember doing is tur the distributor cap a little bit but i put it back pretty close to were it was.....
when i crank it over it just starts to fire and then quits....and then i get really black smoke coming out the tail pipes.....
and when i cleaned my plugs they smelled like some one soaked them in gas.....
What do you guys think it is?????????????????
Old 04-19-2006, 10:00 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Car actin real dumb
timing is off because you messed with the cap, it has to be in the EXACT spot it was in, not close because if it moves just a little it will mess up.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 04-19-2006, 11:19 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
I agree with 97cavalier, when you moved the distributor you messed up the timing. Get a timing light and get it set right, should fix it up.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
so wat your sayin is it has to be the timing........... theres no other possible things it could be???????????
Old 04-19-2006, 11:23 PM
If you moved the distributor, you probably messed up the timing. Since you remember moving it that would be my first step is trying to find a solution. Work the problem, don't guess. Start with the timing, and if that don't fix it troubleshoot for other things. With cars there is hardly ever a time when you know it is something for a fact, but with the information you gave us that is my best beginning of a solution for you. Fix the timing and get back to us if it don't work, maybe we can think of something else.
2006 Hyundai Sonata
Old 04-20-2006, 11:53 AM
97cavalier's Avatar
i am 99.9% positive that is what it is, my buddies truck did the same thing when he messed with the cap and we found out excetly where it was soposed to be and aligned the cap back up and it ran perfect.
Old 04-20-2006, 01:26 PM
oK iMA GO SET THE TIMING OVER AGAIN........imma get back to you guys...
Old 04-20-2006, 02:50 PM
kahjdh's Avatar
kahjdh kahjdh is offline
backfire through the carb is almost allways timing. I try to mark that stuff before i move it.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 04-20-2006, 09:52 PM
yeah it was timing its running now......., running kinda rich but its running...... appreciate everyones input....... thanks
Old 04-20-2006, 09:57 PM
97cavalier's Avatar
now just lean the carb out some and you should be good to go.
Old 04-20-2006, 10:15 PM
See, just listen to us, some of us actually know what we are talking about.
2006 Hyundai Sonata
Old 04-21-2006, 12:43 AM
yup....... o one last question will changing my o2 sensor help it from running rich???????
Old 04-21-2006, 11:40 AM
97cavalier's Avatar
well it is a carb right? so just lean it out with the screw.
Old 04-21-2006, 07:11 PM
Yeah it aint starting now... it just keeps spittin out gas out my carb...... at the last minute it wont start and its makin be go crazy it just started 10 minutes ago and i didnt evn do nothing to it.... i just turned it off..
Wats Goin On?????????????
Old 04-22-2006, 08:16 AM
kahjdh's Avatar
i think you might be flooding it, just adjust the mixture screw on the carb.
Current Cars:
Past Cars:
