Old 04-19-2006, 09:46 PM
mabowens mabowens is offline
94 Chevy Silverado Smokes when started
I have a 94 Chevy Silverado that emits blue smoke when started after sitting overnight. Any ideas what causes this and how I can fix it? Thanks guys
Old 04-19-2006, 10:01 PM
heavyredchevy's Avatar
heavyredchevy heavyredchevy is offline
Re: 94 Chevy Silverado Smokes when started
I have this same problem. Its probably your valve seals. What happens is over a period of time your valve seals get worn out causing them to leak oil into the combustion chamber, in doing so, the engine will produce a blue smoke for a couple of seconds after start up. You should take your heads off and rebuild them.
Old 04-20-2006, 12:29 AM
2000CAYukon 2000CAYukon is offline
This is due to the fact that GM only used a single o-ring as a valve seal on the exhaust valve. The o-ring dries out and cracks, then blue smoke at startup.
The valve seals can be replaced without removing the head. You need a valve spring compressor for this job. Compressed air to hold the valves in place makes it a little easier; although, it can be done without compressed air.
Felpro makes a premium exhaust valve seal that is better than the stock o-ring. I have a complete set of valve seals, new springs (you would not reinstall 100K+ mile valve springs) and rockers in the garage. I had shoulder surgery that has taken longer to heal than expected. Once it is better I hope to knock out the valve seals on my 90 K1500 5.7.
//2000CAYukon
Old 04-20-2006, 03:21 PM
jveik jveik is offline
a classic smallblock problem...
Old 04-21-2006, 12:56 PM
roadrunner_70 roadrunner_70 is offline
Send a message via Yahoo to roadrunner_70
Check out this old thread. You might find it interesting.http://www.automotiveforums.com/vbul...ht=Valve+seals
