Old 07-16-2002, 08:49 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Drum Brakes Sqeak
I have no knowledge on drum brakes whats so ever, everytime i try to come to a stop they sqeal like i ran over a rabbit and it got stuck in the shocks or sumthing, does anyone know what the problem may be and how i can fix it??
PUN
2002 Acura TL Type S
1991 Honda Crx Si
Old 07-16-2002, 08:59 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
take off the drum and make sure you got brake pads left. then get some brake cleaner and spray down your brakes good. squeaking can be caused by brake dust on brake pads.
Old 07-16-2002, 09:42 AM
jc836 jc836 is offline
Another possibility is that the high temperature grease used between the backing plate and the shoe is gone. This assumes that you have not worn down to the rivets. You need to take a careful look inside and also make sure that the adjustment is correct.
Old 07-16-2002, 12:22 PM
Thanx fellas, appreciate it
1991 Honda Crx Si
Rear Brakes Sqeak kpnavarro Crown Victoria 2 02-21-2010 04:58 AM
93 drum brakes stuck andante147 Escort 3 08-31-2009 08:43 PM
El Camino drum brakes to s10 disk brakes punker2083 El Camino 2 01-19-2005 03:47 AM
92 Drum Rear Drum Brake Pads samsamdog Continental 2 02-29-2004 01:12 AM
2000 cavalier - convert rear drum brakes to disc brakes m4dg33k Cavalier 5 11-16-2003 12:04 PM
