Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-19-2006, 06:25 PM
lightorch lightorch is offline
Send a message via AIM to lightorch Send a message via Yahoo to lightorch
Code P0500 "Vehicle Speed Sensor"
2002 Ram, 1500, 5.2 engine, Standard Transmission
Can you tell me where the sensor is mounted? I thought it was mounted on the left side of the transmission, but it doesn't look like the replacement sensor I bought. The new one won't fit because the screw base is larger.
Any ideas are appreciated.
Thanks,
Bruce
Old 04-20-2006, 07:09 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Code P0500 "Vehicle Speed Sensor"
not 100% sure about the 02's, but on my 99, the speed sensor was on the top of the rear axle. might check your rear axle, if it's the same as the older ones, it's bolted to the axle with the same stud as the rear break line "T".
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 04-20-2006, 03:48 PM
It was on top of the real axle. I replaced it and it's fixed.
Thanks for the info scoutinkeith
Bruce
