Old 04-19-2006, 06:02 PM
ZDuRose ZDuRose is offline
Engine Swap
I'm moving my D16a6 from my 89 Civic Si into my 91 CRX HF with the D15b5, it should just bolt on over right? Or do I have to rewire anything. Also how much of the suspension would fit into the CRX?
Old 04-19-2006, 11:51 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Engine Swap
As far as i know it should bolt up just fine since a D is a D. The wiring shouldnt be a problem since your HF is also mpfi so it seems like it should be an easy swap. Dont know about the suspension...good luck
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-20-2006, 01:08 AM
Hybrid1990crx's Avatar
Re: Engine Swap
im pretty sure the wiring harness' are diffrent, but i think if you use the harness from the HF you should be ok.
Old 04-20-2006, 01:11 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Engine Swap
Yeah just use all ofthe wiring from ONE car, and plug it all in..same sensors.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-20-2006, 01:43 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: Engine Swap
if you are putting it in an hf you need to change the hf knuckles or else your si axles woint fit. just nice to know before you tale the engine out.
