Old 04-19-2006, 05:29 PM
Furbert2 Furbert2 is offline
Help with 1999 Grand Prix
Having trouble with tac not working, trax light off going on and service engine light coming on, not all the time-intermittent.
I took it to the dealer when lights were on; they said I needed a new PCM. (Condensed story)
I now have a new PCM and much poorer in the pocket book, the car does the same as listed above no help from dealer except to throw more money at the car.
One last thing today the engine surged the trax light came on and the car died.
Thank ... I was not on the freeway.
As always my car resets its self once I turn the engine off and on again. What I mean by reset is the tac works, trax light off is not on and the service engine light is off.
Some days I have a wonderful car, yea it works... don't ask me about the other GM days...
I have a 99 Grand Prix GT 3800 over 100,000.
Thank you for any help or sledge hammer suggestion!
Old 04-19-2006, 05:45 PM
radeck radeck is offline
Re: Help with 1999 Grand Prix
trac off, and abs light is most likely caused by bad cable or connection. Check your cables, and connactions to the wheel hubs. Just shake them one by one and observe trac off abs light, if connaction is bad light will go on and stay on. SES light it's probably different issue or maybe not, just my 2 cents...
Old 04-19-2006, 05:53 PM
BNaylor's Avatar
BNaylor BNaylor is offline
It figures on the dealer. I've never known one that could troubleshoot or find a bad crank position sensor. Especially if the Tech II machine doesn't tell them anything.
Replace the crank position sensor and you'll be back in business.
Timeslip 08/12/06
AF Community Guidelines
Old 04-19-2006, 07:21 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Bob, yous the MAN! Great example on how valuable this forum is...: )
Old 04-19-2006, 07:40 PM
BNaylor's Avatar
Thanks for the kind words and confidence Paul. You've got me blushing. If I can help people save money, help avoid a rip off dealer or mechanic (both ASE and non-ASE) or shed some light on an issue I'm happy. Like being a good Samaritan. Best part is the help is free on our forum.
Timeslip 08/12/06
Old 04-20-2006, 11:26 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
bnaylor3400 (Bob) IS the man, that's for sure. I am also amazed that a dealer didn't know that a bad crank sensor would cause your symptoms. Just goes to show you that even the dealers have "parts swapper monkeys" that have no diagnostic skills. Welcome to the Forums Fubert2, I hope you find more answers on here BEFORE you trust the dealer. We do our best to steer you in the right direction. You're in very capable hands, especially with our friend and resident expert bnaylor3400.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-20-2006, 03:47 PM
Thank You all for your time I do appreciate it very much. I will keep you informed on my journey to get this baby fixed.
I would like to see if this car last's longer than my 1989 Grand Prix 3.1 that blew a head gasket. It only had 140,000...
Again Thank You! Have a wonderful day.
I love reading this site.
Old 04-20-2006, 06:15 PM
wlkjr's Avatar
wlkjr wlkjr is offline
I have over 305,000 miles on my '97 and it stills runs very well and gets 25 mpg. The most I have spent at one time was about $425 on oil line,water pump, plugs, wires, cleaning injectors, and something else that I can't remember. A mechanic did that job. The other big expense was wheel hubs for $319 and I did the labor. I also did another water pump, rebuilt the alternator at 235,000 and it wasn't even out yet--cost for that was about $60, driver side power window switch, 1 new belt, a few small items and about 60 oil changes all of which I did except one. This has been the best car I've ever owned. Knock on wood. Hope you have as good luck as I have.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 04-21-2006, 06:14 PM
Wow I only wish I had not got a lemon. From the very first I had it into the dealer more than I drove it. So this episode does not surprise me. Since my last tango with the dealer I have decided to put up with the problems while I try to research more since I was so kindly pointed in the right direction. I wish my car came off the same line as your!
Old 04-21-2006, 06:16 PM
Thank you again for your time I do appreciate the help!
Old 04-21-2006, 08:54 PM
wlkjr's Avatar
For once I seem to be the lucky one. Mine seems to the exception rather than the rule.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 04-22-2006, 11:29 AM
Blastorama Blastorama is offline
Replace your Crankshaft Position Sensor.
Old 04-30-2006, 02:12 AM
bcampbell bcampbell is offline
i wish i also had gotten one of the better grand prix's. this is the biggest piece of junk i've ever owned. haven't been here since aug. of last year looking for help because, frankly, i gave up and i've been waiting to wreck. now i seem to have a slight idea what might be wrong but i don't know for sure. trac light went off and stayed off. the manual says if the brakes get too hot that will happen. that's one of 3 choices. feels like i always have a flat tire or brakes are sticking or something is hanging down in front of my tires making it drag.
