Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-19-2006, 03:18 PM
GreyGoose006 GreyGoose006 is offline
9c1 suspention parts
Will the "Heavy Duty" 9c1 shocks fit on my non 9c1 '84 sedan. my shocks are dead, and i was hoping i could replace them with the 9c1 ones for better body control, but im not sure if they have the same dimensions and such.
also, were the springs any stiffer on a 9c1, and if so, could i swap them in for my non 9c1 springs.
sorry if you covered this in the 9c1 engine poll, but i couldnt find it.
-thanks
Old 04-19-2006, 04:52 PM
CD Smalley CD Smalley is offline
Re: 9c1 suspention parts
Yes to the shocks fitting.
Yes the springs are stiffer.
Yes to the swap of the springs.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 04-19-2006, 06:48 PM
HLandin's Avatar
HLandin HLandin is offline
Yes, the shocks and springs were stiffer on the 9c1 package. This is especially true of the boxy 9c1, which were stiffer than the whale body 9c1 package.
Old 04-19-2006, 08:17 PM
What do you think of KYB shocks. are they any good?
Old 04-19-2006, 08:42 PM
Love them on my Astro van.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 04-20-2006, 01:54 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
yes yes and yes, most suspension parts will fit, like my caprice, i have 9c1 springs and shocks all the way around, then i put on 9c1 sway bars.its all on a civilian caprice, thing handles great i love it, alot stiffer.
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-20-2006, 03:07 PM
Dont you need to drill holes in the frame to mount a rear sway bar? i dont immediatley see the holes to mount one on the rear
Old 04-20-2006, 03:45 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The rear sway bar does not bolt to the frame, it bolts to the lower control arms. If your lower control arms do not have the mounting provisions for the sway bar, you will have to either change them for ones that do (a lot of work) or go to a GM parts dealer (ie. car dealer) and buy a mounting kit (goes into your lower control arms, much less work).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-21-2006, 05:46 PM
1986Z28's Avatar
Has a Camaro
mine had the holes, but come on changing lower control arms isnt that hard, ive done it before on my buddies 94
Old 04-21-2006, 10:03 PM
Blazin_Jason Blazin_Jason is offline
http://impalassforum.com/noncgi/ulti...;f=16;t=005103 That's the reason I'm going to get aftermarket arms right away. Just to avoid any future problems.
Old 04-22-2006, 01:34 AM
1986Z28's Avatar
Has a Camaro
good idea
Old 04-22-2006, 06:59 AM
Do note though the owner had installed an aftermarket rear bar which was much stiffer than the stocker.
The stock LCAs, which you can get as a complete set from GM, should be fine for normal street use with a STOCK bar.
My 9c1 has 190k on the clock with a stock sway bar and the stock LCAs. I see nothing like this on my car.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 04-22-2006, 11:37 AM
silicon212's Avatar
Confoundingly Lucid
Ditto my car. I've inspected the entire suspension on the back, and I've not seen any stress cracking on mine.
Old 04-22-2006, 04:11 PM
my uncle installed really stiff solid sway bars on his 69 GTO, and it ripped the bolts right out of the frame. they had to weld a 1/2 inch plate on top of the frame and get longer bolts to get it to work. now it rides like its on rails.
Silicon and others
how much for this mounting kit and what kind of things do you need to do to install it. im not too scared about the actual work, but i have a shortage of tools!!
Old 04-22-2006, 04:25 PM
1986Z28's Avatar
Has a Camaro
no problems with mine eiother
