Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-19-2006, 01:38 PM
Katterinablu Katterinablu is offline
Gear Ratio Question
Hi,
I'm a Wrangler Virgin and I will be changing my stock tires on my 06' SE to 31x10.5
I have already done the calculations and know which gear ratio I need, but I just wanted to ask, do I have to change anything else apart from the ring and pinion?
Like I say I am completely new at this, and probably wont attemp the job myself unless its very easy.
Any help would be appreciated.
Thanks
Old 04-19-2006, 04:34 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: Gear Ratio Question
Changing the R&P is a procedure that takes a high amount of mechanical skill and special tools and gauges to do the job. It would help to have more information such a the axle types (Dana 35c,44 or other), transmission type (auto / manual) and what your expectations are.
Old 04-19-2006, 08:52 PM
Thanks for you reply. In answer to your questions:
I have the stock axel Dana 35 i believe
Manual Transmission
Basically I understand that having 31" tires with my 3.73, will make it feel like I'm running a 3.18 is this true? I would just like to balance everything out. This sounds like an expensive job. Could you give some advice as to what I can do? My stock tires are pathetic. Generally when people get larger tires how do they compensate?
Thanks
Old 04-19-2006, 08:59 PM
DwightRGV DwightRGV is offline
You may want to live with the tires a while before going to the trouble or expense of changing gears. I drove my 98 TJ and 3.73 gears with 33" tires for 6 years. It is not the best, but you get use to down shifting. I only changed my gearing because I broke several teeth on my rear ring gear and one the pinion.
Old 04-19-2006, 10:21 PM
csparks78 csparks78 is offline
Hey not to get off track here but My 01 TJ SE was in the shop last week because of a stolen PCM and I was at the Jeep safari in Moab so I rented a 06 Sport and a little bit into Fins and Things a 3 1/2 out of 5 trail I tore the hell out of the ring and the pinion gears barely made it out of there. My question is how hard are they to break??? I broke them so easy im going to be scared for awhile now with mine. I heard on the trail from some guys that they are hard as hell to break... was it maybe because it was a rental???
Old 04-20-2006, 09:13 AM
Thanks for your reply. 6 years is a while, So you would have kept the 3.73 if you didn't bust you gears?
I'm happy to keep the gears, but I was under the impression the engine would have to work harder, and I wont even mention the ridiculous acceleration I will get... but I guess I didnt buy a Wrangler for the speed.
Incidently, how much did it cost to replace the gears?
Old 04-20-2006, 09:28 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Check out these sites, they will give you an idea of how your tire size will affect the ratio:
http://www.dakota-truck.net/TIRECALC/tirecalc.html
and
http://www.1010tires.com/TireSizeCalculator.asp
Both will give you an idea of the % that your speedometer will be off, which in turn will give you the % change in your effective axle ratio.
I'd have plugged in the numbers, but don't know what your stock tire size is.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-20-2006, 09:30 AM
Oh yeah, and also the Wranglers with the 30" tire package come with the 3.73 ratio, so 31" isn't that much more; DwightRGV has a good point - live with them for awhile, you may find they're ok.
Old 04-20-2006, 10:43 AM
neon_rt's Avatar
If you have 3.73 gears, they should work OK for you.
The standard gear set for a Wrangler w/manual trans is 3.07.
The standard size tires are 28" with the 3.07s, with the 3.73s you could go up to 34" before you would reach the same RPM/MPH as the standard setup.
My Cherokee 5-speed has 3.07 gears. It seems a little high and it goes too fast in reverse, but I can live with the 22mpg I get with it, so I will leave it be.
Old 04-20-2006, 06:33 PM
Thanks for all your advice. I've decided to stick with the 3.73 gear ratio as I will probably only ever run a 31" tire because I'm not a hardcore 4 wheeler anyway Plus you guys seem to think its ok, and as you know way more than me I'm sure I'll be fine.
Old 04-21-2006, 06:20 AM
Ray H Ray H is offline
I may be wrong about this but isnt your Jeep a 4 cyl? I thought the 4 cylinder Jeeps with the 6 spd come with 3.73s.
I think that if you have the 4 banger with 3.73s and go to 31s, it will pretty much suck.
Old 04-21-2006, 06:43 AM
Good point, Ray. SE's with the 4 cylinder come with 4.10 gears.
Old 04-21-2006, 08:06 AM
They used to prior to the 6 speed tranny. Ill have to check this out but I think if you go to Jeeps website, they show the SE with the 2.4 and 6 speed as having 3.73s.
Old 04-21-2006, 09:27 AM
Mine is the 2.4l 6-speed and it does have the 3.73 gears. So you're saying bigger tires are gonna suck with my engine? I know I'm going to be slower, but do you think its going to be ridiculous?
Old 04-21-2006, 09:29 AM
Oops, forgot about the 6 speed.
