Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-19-2006, 01:37 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Angry Still removing valves...
Hey all;
I'm still having problems removing the valves from my new head. I even bought one of those valve removers... and it doesnt work for a DOHC, on SOHC where the valves are staright up. I'm getting so pissed at this. I got 4 valves out using a C-Clamp and some little piece of metal that I found. However, it's crushed now. I posted back and someone showed a tutorial on how to weld a open socket onto a C-Clamp... I dont have a welder. Is there anyother way to get at those weird angles and get them out?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-19-2006, 01:45 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Still removing valves...
That's what I had to use to get the valves out on my 420a...the cut socket and a modified spring compressor. I'm not sure what else ya could do man, just keep trying. It took me forever to do it, and that was with the help of my auto teacher.
95 Talon TSI AWD
97 Eclipse GST
Old 04-19-2006, 02:17 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I've got something you could use, similar to the socket but slighly different. You live in chicago right?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-19-2006, 04:07 PM
david-b's Avatar
Dave is THAT guy
OK... I relaxed, and I took my time and got them all off. I took a piece of metal strip, I think it came with my CAI, and bent it into a square, slightly smaller than the size of the spring. I kept like a "handle" on it too. I took the C-Clamp and pressed down where the handle meets the squarish part and tightened it. Then took out the little pieces then. So I finally got them all out.
Next question... in order to clean and port it, do I have to take out the guides/seals? They look like they dont come out and I don't want to break them. Or, can I do the work with them still in it.
And FYI, I'm doing the port job myself. Should be fun!
75 Monte Carlo
Old 04-19-2006, 04:56 PM
I didn't remove anything when I ported mine, not even the valves. Just make sure you stick a paper towel in the ports before you port them to prevent metal shavings to get everywhere.
95 Talon TSI AWD
97 Eclipse GST
Old 04-19-2006, 07:10 PM
david-b's Avatar
Dave is THAT guy
I'm not going to do any damage to the guides when washing it, am i?
What should I use to wash it. Its got a lot of oil on it.
75 Monte Carlo
Old 04-19-2006, 07:17 PM
MexRocket's Avatar
MexRocket MexRocket is offline
You have a compressor right? for porting? Just stick the towels in their so it doesn't get messy. Man i just copied someome.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 04-19-2006, 08:46 PM
Well what all are you washing and with what? I'm not sure if it'll hurt them or what it'll do, I would probably go ask a machine shop and see what they think.
95 Talon TSI AWD
97 Eclipse GST
Old 04-20-2006, 01:07 AM
david-b's Avatar
Dave is THAT guy
That's what I'm asking... what should I wash it with? Water? There's ALOT of build up... heads got over 100,000 miles.
75 Monte Carlo
Old 04-20-2006, 02:15 AM
I don't even know washing it with water would get all that shit off. If I was you I'd just bite the bullet and take it in and have it at least professionally cleaned to make sure that it's perfectly clean when you get it back.
95 Talon TSI AWD
97 Eclipse GST
Old 04-20-2006, 12:26 PM
ez1286's Avatar
WHy don't you just replace the valve stem seals? If they have 100k i'd replace the while you have the head off.
I use this stuff the comes in a black can and says "steam" in silver letters up the side. I works wonders especially on internal parts.
Old 04-21-2006, 12:37 AM
david-b's Avatar
Dave is THAT guy
I talked with a friend who knows alot of DSM guys around the area. One of them ownes a detailing shop. He said to use Gasket Remover and hot water and let it soak in there for a good hour or so. Then take it to a DIY car wash with the pressure washer and blast all that shit out. He said it'll work.
75 Monte Carlo
Old 04-21-2006, 01:07 AM
ez1286's Avatar
The stuff i said works wonders, and instantly. Plus no trip to the car wash.
Old 04-21-2006, 06:47 AM
Well next time I get some head work done, screw the machine shop, I'll just clean the sucker myself. I wasn't sure if water would be such a good idea but now that I think about it, what is there to hurt? Nothing really. Let me know how that works out for you david.
95 Talon TSI AWD
97 Eclipse GST
Old 04-21-2006, 11:03 AM
E-Klips E-Klips is offline
Banned
When I ported my head, I left the valve guides in but took everything else out just for the fact that I took 3/8" off the bottom of each port. Then I just took it to my buddys machine shop and had him hot tank it. Took 10 mins and it was cleaner than you could have gotten it anywhere else. Normally it cost about $20 but I got it done for free.
