98 Camry CE V6- warning lights
Hello... I cannot figure out why i am having the rear light warning light staying on. I have replaced all the bulbs and the light still stays on! Is there something somewhere some bulb I missed??? Please need your help.
Re: 98 Camry CE V6- warning lights
Most likely this is not the bulb. It gets powered on by the transmission put in reverse. That is where I would start looking. There should be a switch somewehere. I unfortunatelly do not know where it is located. Try to check with Haynes manual or so.
Sam
Might be something here that can help: http://experts.about.com/q/Toyota-Re...ail-lights.htm
This is for the wrong year but it might show where this sensor is and what it looks like: http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW |
Hello SAM, Is this the rear light sensor switch that I am looking for? |
Also, check the loom of wires inside the trunk by the driver's side trunk hinge. The wires in that loom have a tendancy to break from all the flexing that loom is exposed to when the trunk is opened and closed. Open the loom and look for broken or frayed wires. Repair as necessary.
Mike |
Thank you everyone for your recommendations. I will try to see if this works. Keep you posted.
