Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-19-2006, 12:51 PM
Juggalo Juggalo is offline
Question cam gear ?
i was just wondering about how much time is involved in replacing cam gear's to aftermarket ones ( Obx ) and also how much hp can i get from advancing my timeing? would it be worth the money to do it or would it not be enough of an increase and just save the money for something else? just a few questions.. any help would be great! thanks
Old 04-19-2006, 01:00 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: cam gear ?
You have to pull off the timing belt, replace the cams, and then install a new timing belt. Replacing the cams themselves isn't tough, it's everything you have to do to get to them that's a waste of time. IMO it's not worth it unless you've done extensive engine modification in other areas.
95 Talon TSI AWD
97 Eclipse GST
Old 04-19-2006, 04:23 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: cam gear ?
I added cam gears when I changed my timing belt. Right now my are set to advance the intake cam 3 degrees and retard the exhaust cam 1 degree. I did gain a couple of hp, but its not worth spending a few hundred dollars on them. My idle also has a little chop in it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-20-2006, 09:01 AM
Re: cam gear ?
i know it may seem like a waste of time and money but im working w/ a 420a here and im running out of "cheap" things to do for a little hp.. what else can i do besides what ive allready done that doesn't involve pulling the motor b/c i can't afford to be down for a few days doing stuff and i don't have alot of money to work with here.. and suggestions would be great!
Old 04-20-2006, 02:09 PM
Re: cam gear ?
I would say go with a bored TB next and get the intake mani to match it. And how about an underdrive pulley? Those are supposed to be one of the "biggest bang for your buck" mods for the 420a.
95 Talon TSI AWD
97 Eclipse GST
Old 04-20-2006, 06:01 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: cam gear ?
Yeah, I second the pulley. I know its like comparing apples to oranges, but some magazine dyno'd their RX8 before and after a underdrive pulley. Something like 10 hp and 13 ft/lbs of torque. I think cam gears are worthless unless you are running cams.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-20-2006, 09:51 PM
Holset powered 420a
Re: cam gear ?
Go with an UDP first, then get a bigger TB.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-20-2006, 09:54 PM
alphalanos alphalanos is offline
Re: cam gear ?
I agree with the posts. cam gears are useless without other engine work. a TB, intake mani should get you 10hp.
96 EJ6. Future home of boosted B18C1.
Old 04-20-2006, 11:04 PM
Re: cam gear ?
i just bought a 55mm Tb from a guy off 2gnt.. its supposed to be here next week sometime.. how much is a UDP? any certin kind better then the next? thanks for the input!!
Old 04-21-2006, 06:36 AM
Re: cam gear ?
I believe Unorthodox sells a good one but I'm not sure, I haven't really looked into them much yet, I'm more concentrated on my turbo rather than the 420a
95 Talon TSI AWD
97 Eclipse GST
Old 04-21-2006, 02:29 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: cam gear ?
AFX underdrive from howellautomotive.com is another option. I have that on my car, and yes UDP's do help quite a bit.
Wow its been forever since I posted here..
For Sale 98 Eclipse GS, 5 spd
Old 04-22-2006, 09:15 AM
Re: cam gear ?
hey what's up ashah, haven't seen you in like 5months or more.. welcome back and thanks for that link
Old 04-26-2006, 03:03 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: cam gear ?
cam gears are a waste of time. the ECU will retard timing and correct for anything you do with the gears. the only thing that i like about them is that they make my engine look faster. don't get me wrong. with hours of dyno time i'm sure you could squeeze a couple of HP out if it... i think...
Old 04-26-2006, 11:47 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: cam gear ?
If you get aftermarket cams, than it is advisable to get adjustable cam gears.
1991 GSX 2.3 Stroker
Old 04-26-2006, 01:41 PM
Re: cam gear ?
I agree, but putting cam gears on a stock car with not many other mods is pretty pointless.
Juggalo, install that TB and get an UDP and you should be pretty happy.
95 Talon TSI AWD
97 Eclipse GST
