Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '88 - '92
Old 04-19-2006, 12:10 PM
spider69ca spider69ca is offline
Send a message via ICQ to spider69ca
cooling fan won't start
is there a way to check if the fan motor is good?
thx in advance nick
Old 05-04-2006, 09:03 AM
spasticone spasticone is offline
Re: cooling fan won't start
If you haven't done this yet.... on the right side of your engine (sitting in the car) at the front corner of the engine where the valve cover meets the block there is a switch with one wire running to it. if you ground that wire, the fan should turn on. If you have a manual it should show that as a fan switch I believe.
