Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-19-2006, 07:52 AM
jamesmetairie jamesmetairie is offline
95 won,t run.
friend of a friend has 1995 with about 90,000 miles and it just flat don,t want to run. he says it,s been to 3 or 4 mechanic,s already. they,re still scratching they,re heads. NOW it,s been sitting in the back yard for 2 years. any educated idea,s will be appreciated. thanks.
Old 04-19-2006, 10:36 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 95 won,t run.
We are gonna need a lot more details than just... "1995 with about 90,000 miles and it just flat don't want to run."
What trim level is it? Was he driving it when it stopped working? Was it setting for months before he drove it? Did he beat the hell out of it? What?... We need soooo much more information than that... Theres probably about 1000 different things it could be on a DSM and nobody is gonna make a whole list of things it could be without more details.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-19-2006, 11:23 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: 95 won,t run.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-25-2006, 10:15 PM
Tylrdurdan Tylrdurdan is offline
Re: 95 won,t run.
Check all the small stuff....like spark, see if you got any fuel pressure....
Old 04-26-2006, 01:25 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 95 won,t run.
I'm going to elaborate on this a little bit, just because I actually feel like being helpful. Yes, check all the small stuff. First of all, make sure the battery is charged, and that the car turns over.
Next, make sure the spark plug wires aren't corroded and are delivering spark efficiently, and the plugs are in good condition. A car needs 3 things to run: air, fuel, and spark. We've just eliminated spark. Next go with fuel. Make sure there is good gas in the car and that the plugs are actually getting gas. If you clean the plugs and put them in the car, turn it over, pull the plugs out, and if they smell like gas and are wet, that's a good indication that you're getting fuel. You could also do a fuel pressure test. Lastly, if you get the car to run, replace the air filter and fuel filter to make sure it's getting the best of both.
And like blackcrow said, we need more information. Turbo, non-turbo, tranny helps, was he driving it, did it make noise, did it start smoking, etc..
95 Talon TSI AWD
97 Eclipse GST
