Old 04-19-2006, 07:09 AM
pako7169 pako7169 is offline
Not Starting
My van does`nt want to start, engine won`t even crank battery is good. narrowed it down to starter, how do I remove it?
Old 04-19-2006, 11:55 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Not Starting
Hello
Welcome to AF!
First off, check the small wire on the starter solenoid. I’ve had this get loose and cause a no start situation. If this isn't the case, here is a rough guide to get the starter off.
I would put the van front end up on ramps. Disconect the ground on the bat. Remove the two bolts that hold the starter on. (you may have to remove shilds and other items to access the starter.) Remove the wires. Reverse to install.
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
