Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 07-16-2002, 12:13 AM
TheLogikal1's Avatar
TheLogikal1 TheLogikal1 is offline
Send a message via AIM to TheLogikal1
reliability??
how reliable is the fd? say around 73k miles? hell, how realiable is that car at all?
Old 08-10-2002, 03:11 PM
RXtony7 RXtony7 is offline
Send a message via AIM to RXtony7 Send a message via Yahoo to RXtony7
Like any other car the rotary is only as good as the maintenance it has had. You dog any motor and it's not gonna last. Average life of a rotary that has been run to death is 100k or less, I have seen some that where babied, and lasted for 200K.
Street racing is bad...mmkay
1986 Mazda RX-7 GXL
No rotor no motor
1998 Ford Ranger
4 bangin' at it's best
www.firstflightcruisers.com
Old 08-11-2002, 12:42 AM
Kaneto's Avatar
Kaneto Kaneto is offline
Send a message via AIM to Kaneto
The one thing you have to always keep in mind with a rotory is that it eats oil by design. While on most piston engines you can just change the oil every 5k miles and neglect it the rest of the time, you can't do that in a rotor. You'll just wind up running out of oil and destroying the engine. Check the oil every time you fill up, and put some more in when you get low.
Old 08-24-2002, 11:55 AM
delsolsi delsolsi is offline
I drive mine really hard, going to redline all the time and sometimes past it. I have 170K miles on it. No engine reliabilty problems, some electrical problems but from what I've seen surfing the net eletrical problems are common on 2nd generation.
Old 08-26-2002, 06:52 PM
Kaneto's Avatar
That's another thing... RX-7s are meant to be driven hard. If you baby it too much and always keep the revs down below 4k, you'll build up carbon deposits from the oil being injected into the combustion chamber. Eventually when those deposits get to be too much they can score the housings and even cause the engine to seize.
I hit 6 to 7k+ RPM at least a couple times a day any my car loves it.
Old 08-26-2002, 11:53 PM
Steel's Avatar
Steel Steel is offline
uh speaking of which, my rex has a rough idle, and i dunno what it is. When i drive normaly, either bashing or babying it, it purrs, but when it comes to idle, i can feel to bump around, and see the needle tweeter. It has died a couple times on me right when i started if i didnt hit the pedal real quick, and sometimes when i start it, (cold) instead of shooting up to 3000 rpm's for 20 seconds like it should, it goes back anf forth between 1000-1500 rpms. Electrical, or engine?
anyone have reliability problems? NissanZ@af 1st Gen 95-99 5 12-20-2001 01:05 AM
Reliablity over 100,000 miles? RD7 Maintenance 9 09-13-2001 07:58 PM
328i reliability jdavis 3 Series 4 08-30-2001 10:47 PM
WRX reliability? Kerberos1278 Impreza/9-2x/Outback Sport 4 08-25-2001 09:53 AM
