Old 04-18-2006, 11:41 PM
nvrhapy nvrhapy is offline
electrical problem
hey guys i'm new but had my 91 crx for a few years now. my crx has a b18 in it and the basic mods i/h/e. and is still slow as hell, but thats not the main problem right now i have an issue with the car starting, it starts when it wants to. if i hook jumper cables up to it then it will start. but other wise i just turn the key and get nothing, the dash lights come on and everything but the car won't start. i checked and used numorous batteries and it happens with many differnt batteries. even if the battery is at 12 volts it won't even turn over sometimes and try to start but for some reason if i jump it it will fire everytime. any ideas on how to find the problem?
Old 04-19-2006, 06:04 PM
skotman's Avatar
skotman skotman is offline
Re: electrical problem
you've switched the battery with other new batteries, so that's not the problem.
battery terminals / battery cables perhaps? even if corrosion isn't visible, it's sometimes hiding underneath that plastic covering. it's a relatively cheap fix to relpace both the positive and negative battery cables. sometimes the extra current from jumping the car with jumper cables gives you enough juice to um... i dunno... bypass the corrosion?
other than that, what condition is your starter in? have you tried using the hammer trick, where someone turns your key while you tap on the starter with a hammer? the idea is that you knock corrosion loose with the hammer while it's trying to turn over, and if successful, your car will start.
i've never had a starter so old that it needed the above trick, though. i'd imagine it would have had to be damaged by salt and water or just very very old to be that corroded, but it's worth checking before you blow money on something that won't fix the car.
Old 04-19-2006, 06:26 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
id say alternator, but if it wont even start when you got full juice then i cant really add anything to the conversation. maybe alternator? i dunno just throwing it out there.
gimme some time. ill think of something witty and clever to put here.
Old 04-19-2006, 07:02 PM
well the car has a new alternator, and i tried the tapping on the starter but that didn't seem to work i thought it might of been in the ignition or something but i dunno.
Old 04-20-2006, 10:27 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
your car doesn't have anything mechanically wrong with it if it starts when you boost it. Your alternator and starter are good. It's most likely in your battery cables and terminals. Check those as well as the tranny ground, and valve cover ground and thermostat ground. Make sure the two wires going to the starter are nice and tight.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-23-2006, 09:21 AM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
check your starter, my EG does that. I need a new starter.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 04-23-2006, 04:37 PM
88CRXDemon's Avatar
88CRXDemon 88CRXDemon is offline
Send a message via AIM to 88CRXDemon
yes check your grounds like he said, I had a problem much like yours a few weeks after I bought my Rex, turned out to be a really loose ground wire from the battery
B18 powered primer gray '88 CRX HF
All motor LS/Vtec being built by D2G coming soon....
'95 Eagle Talon TSi AWD daily driver
Old 04-26-2006, 02:32 PM
1sikrex's Avatar
1sikrex 1sikrex is offline
Send a message via AIM to 1sikrex Send a message via MSN to 1sikrex Send a message via Yahoo to 1sikrex
Having the same problem with my crx, have plenty of battery power, I would suggest checking your main relay, I bought one off e bay and even though it said "works fine", it most certainly did not. Also I have seen alot of people say in posts to check ground wires. In the process of doing that myself, Ill let ya know how it works out.
1990 CRX DX, DOHC ZC, Cold air intake, upper and lower front and rear strut bars, Spoon chipped ECU 18 inch ADR Titan Gunmetal rims with polished lip, 150 amp alternator, 2 Optima red top batteries, 5 tv's 1 in each sunvisor, 1 in each headrest, Pioneer 6.5 touchscreen dvd player, Monster cable balanced video distribution unit, 2 12" Kicker Solobaric L7, 700x5 Kicker amp, Boston Acoustic 6.5" coaxials, 4 1 inch boston acoustic tweeters, xm radio, 6 disc cd changer. Viper alarm with remote start.
Old 04-26-2006, 06:13 PM
thanks for the help guys, turned out to be a dirty battery ground, cleaned it up and my crx started up just fine. thanks again.
Old 04-26-2006, 09:51 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Glade to hear it! Just because its connected..does not mean its flowing current properly..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
