Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-18-2006, 11:31 PM
camaryfane83 camaryfane83 is offline
mega squirt for 4g63 motor
who knows where i can find a wiring diagram for using megasquirt for a 1991 eagle talon with a awd turbo please help
Old 04-18-2006, 11:40 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: mega squirt for 4g63 motor
www.megasquirt.info?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-18-2006, 11:52 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Or do you mean a wiring diagram for the talon's ecu? If so try VFAQ.COM. Hope that helps.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-18-2006, 11:59 PM
blk_srt's Avatar
megasquirt is a standalone so I dont think he needs the ecu pin out
Mods:
Old 04-19-2006, 12:02 AM
ez1286's Avatar
I thought it was similar to link, he still probably needs the ecu wiring diagram .
Old 04-19-2006, 12:10 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
he only needs the ecu wiring diagram if hes going to reuse the stock sensors and wiring.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-20-2006, 11:12 AM
ok im not using stock wiring but using stock sensors i have the wiring kit from mega squirt but need a true diagram for mega squirt to run on a dsm car 1991 eagle talon tsi
Old 04-20-2006, 01:16 PM
E-Klips E-Klips is offline
Banned
This is exactly why I dont like mega-squirt. You have to mess around too much with installation and the support sucks!
DSMLink is 100 times easier to work with and install than mega squirt is even though mega squirt is a stand alone EMS there is still too much BS you have to do. If your going to go EMS you might as well spend the extra money and get AEM. The support is great, a million more people know how to use it and it is plug and play. No hassle with wiring it up.
