Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-18-2006, 09:29 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Installed turbo timer now alarm doesnt work
I just put in my hsk type-0 and now the alarm doesnt work. Its not the factory unit its an alpine alarm system installed by the previous owner so I dont think the instructions for installing it with the factory alarm will work. Has anyone installed one with an aftermarket alarm? Any help is great
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-18-2006, 11:25 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Installed turbo timer now alarm doesnt work
Did you diconnect any power connections or anythng? Does the alarm work after the timer has shut the car off? Maybe it as something to do with the ignition switch?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-19-2006, 07:26 AM
blk_srt's Avatar
well if I'm thinking about this correctly, the alarm is hooked up through the ignition switch so when you splice the turbo timer inbetween the alarm no longer has a direct route it has to go through the turbo timer and no it doesnt work at all. I can still lock my doors remotly but no alarm
Mods:
