Coolant Leak
I have a coolant leak, in my 3.4. There's no coolant in the oil, and i see no sings of it being burnt. What are some other possible causes?
TIA -Trav |
Re: Coolant Leak
Its probably the intake manifold gasket leaking. Sometimes it doesn't show in the oil, but its still possible its leaking.
- Jeremy |
Re: Coolant Leak
Since I posted last, I went and looked under my car too see if I could find a leak from a hose, and i never found it still, but did notice that the leak is coming from the passenger side of the car (thats where the puddle is) If that is any indication of the problem your imput is appreciated
-Trav |
Re: Coolant Leak
Passenger side could still be the intake gasket, water pump, coolant reservoir or hoses.
Re: Coolant Leak
I agree. I'd check out the plastic reservoir area. There is an overflow hose which will drip out coolant is there is a problem or if overfilled. Also, the cap is pretty flaky so check to make sure it is tight. In order for coolant to come out the overflow the cooling system pressure has to exceed 15 psi which is the rating on the cap.
Re: Coolant Leak
I have checked all the hoses and the resivoir, no leak. My resivoir was empty so i'm assuming the fluid didn't come from the overflow tube. I have noticed that the leak seems to be coming from the more front portion of the side. I can "see" no leak from the water pump, but its hard to see from all the congestion. It seems wet underneath it, I can defenantly see some wetness on the top of the part of the air conditioning pully. Does coolant run through that part? Thanks again for all the imput.
-Trav |
Re: Coolant Leak
There is no coolant flow through the pulley for the AC compressor and clutch. Also, the waterpump has gaskets where it connects to the engine block.
Re: Coolant Leak
right on, Is that at DIY or not. new water pump or just gasket?
-trav |
Re: Coolant Leak
Re: Coolant Leak
alright, thanks alot man. much appreciated
-trav |
