| Let's get Technical! Discussion for hardcore in-depth motor heads! |
I was working and i went to get gas i was on E and i filled it up to full and after i put gas in it it went dead no nothing. some said it was my fuel pump and tricks i can try to see if it is or not?
Re: Car Wont start after gas put in it?
power? spark? fuel pump primes?
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
might have a clogged fuel filter, when you run a tank empty the trash that has collected in the bottom of the fuel tank can clog the fuel filter up tight.
if the filter is clogged then not enough fuel is getting to the engine
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
Moral of the story dont let your gas go past 1/4 tank
make sure to tighten the gas cap
turn the key to the on position and see if u can hear the fuel pump kick on to prime the system.... if so try and bleed the air out of the line at the filter if any got in.. i always had trouble with my crx when i ran on empty it got air in the lines..
85 crx si spun rod bearing..getting new block 2003 dodge neon se ..family car
