Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 04-18-2006, 03:39 PM
bendog67 bendog67 is offline
98 LSS Will not start
My LSS is dead at the moment and I need some advice. What happened: running fine, had lost fluid a month ago but never saw any pools. Going to work and stopped for coffee, came out and would turnover but not start. Added fluids because none in reservoir. Started up and went two miles to office. Left work and less than ten miles later temp went to the red. Towed her home, put on ramps, changed oil and filled fluids. Ran for a few minutes but did not sound right. Shut her off and will not start now. I have taken in the starter and battery and they check out good. When I hit the key it just hits the starter really hard but does not spin the engine. Any help is greatly appreciated. I can spin the engine from the harmonic balancer but not sure if it is going through a complete cycle.
Old 04-18-2006, 06:43 PM
maxwedge maxwedge is offline
A990 racer
Re: 98 LSS Will not start
Fluids, what fliuds? If coolant you better pull the plugs spin it over and get the antifreeze out, then figure on the upper intake having failed at the egr passage but you will need to pull it of and inspect this are closely, obviously if the coolant is in the cylinders a head gasket could cause this, but much less likely the the troublesome upper intake. Was coolant in the oil? Not sounding right what, a knock ,a miss, lots of info is missing here.
Old 04-19-2006, 03:24 AM
Hansnet's Avatar
Hansnet Hansnet is offline
yep assuming you have a non-supercharged lss then UIM is a very likely issue.
Old 04-19-2006, 12:02 PM
No water in the oil. It sounded like it was missing. Thanks for responding.
Old 07-11-2006, 02:40 PM
MANDY_4222 MANDY_4222 is offline
ur security system line from the ignition has popped this action de mobilizes the car u need to have a locksmith remove the secuity line!
Old 07-11-2006, 03:24 PM
A990 racer
Thumbs down Re: 98 LSS Will not start
FYI, this is irrevelant to the original question, which btw is 3 months old.
Old 07-13-2006, 09:28 AM
Thanks for the post Max. Mandy had me confused too. Have not got her running yet. I can spin the engine now. I do have fire at the plugs and fuel to the cylinders. Will not fire up though. I hope to get time in about two weeks to start taking her apart to find the culprit. Any help is still greatly appreciated.
Old 07-13-2006, 10:03 AM
A990 racer
Lightbulb Re: 98 LSS Will not start
Take a compression test, at least the easy cylinders, try spraying carb cleaner into the intake, see if it kicks.
