Old 07-15-2002, 07:38 PM
BIG TX BIG TX is offline
Question Engine Swap
I was wondering how much work it would be to swap a 6.2L Diesel out of a 1982 GMC 3/4 ton 4x4 pickup and put in a 350, 454 because I think the transmission will bolt right up.....but I've been told that the 6.2 was made by Oldsmobile and only a Oldsmobile will bolt right up to it. Anyone have any ideas? please help
Old 07-16-2002, 07:40 AM
higgimonster's Avatar
higgimonster higgimonster is offline
i was under the impression that all the gm deisels were built by isuzu but i don't know about an 82. anyway, find out if your tranny ever came with a 350 (or 454) bolted toit and then you will have your answer (i know this is probably of no help, but i tried )
Promoter of the one line signature.
Old 07-16-2002, 01:53 PM
Hudson Hudson is offline
Old Mod
The 6.2L (as well as the 6.5L) diesel and turbodiesel engines from GM were derived, I believe, from Detroit Diesel designs. They don't have anything in common with Oldsmobile engines.
The original light-duty diesel V8s that were used in GM pickups were "dieselized" versions of Oldsmobile's 350. That engine was replaced by the 6.2L.
Isuzu and GM co-developed the current 6.6L Duramax V8 turbodiesel engine found in Chevrolet and GMC trucks.
These three series of engines (5.7, 6.2/6.5, and 6.6) have no major parts in common.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
