Old 04-18-2006, 12:35 PM
redneck45 redneck45 is offline
pcm removal
Getting ready to send my pcm to Jesse. Once I find it, what is the procedure for removing it? I figure disconnect the battery and pull that puppy outta there?
Old 04-18-2006, 02:58 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: pcm removal
Remove the Negative battery cable and remove the PCM cover. Take the bolt out of the plug that holds it in and wa-la. done.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-19-2006, 11:10 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: pcm removal
Where is the PCM Cover? is it under the hood or under the dash?
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 04-19-2006, 05:14 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Re: pcm removal
Under the hood. If you're looking under the hood from the front, its on the right toward the front of the engine bay. You'll see a little plastic box looking cover there. Just move it around to undo the plastic tabs holding it on and it will just pop off. Easy as pie.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 04-19-2006, 05:21 PM
Re: pcm removal
My three relay electric fan harness is mounted to the pcm cover in this pic.....
Old 04-20-2006, 08:59 AM
Re: pcm removal
Thank you very much!!
Old 04-20-2006, 09:28 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: pcm removal
What make and model?
On a newer silverado some are mounted on the driver fender well.
MT
MT
Old 04-21-2006, 08:39 AM
Re: pcm removal
mmmm pie
