Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-18-2006, 10:06 AM
JunkyardLife JunkyardLife is offline
How long for a 4.3L TBI Caprice to last?
Mine has almost 200,000 miles..When do the bottom ends(bearings, rings, cam) start to give out? Do head gaskets or TBI parts start going bad at certain mileage?
Old 04-18-2006, 10:50 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: How long for a 4.3L TBI Caprice to last?
Depends on several factors including the maintenance schedule, etc. I've seen engines not last 50k miles and I've seen engines last well into the hundreds (mine has 256k on it now). If its strong (for what it is) and has good oil pressure, you're OK. Weak oil pressure would indicate bearing wear.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-18-2006, 11:12 AM
Thanks. I dont have an oil pressure gauge, but the oil light has never came on, so it should be good for a while to come! Im also running 10-40..Which has extra detergents bearings dont like, but with an engine this old it was worth the risk for solid oil pressure and less internal leaking.
Also, what about the trannys? Do they hold up as long as the motors? The fluid is nice and clean. Ive never flushed it, but I imagine the previous owner must have.
Old 04-18-2006, 12:31 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
yeah as he said it all depends on maintanence, my dad had a 305 with well over 400 000km
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
