Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-18-2006, 12:51 AM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
Angry Bunny hop won't stop!
Ok, here is the deal. It just started doing this a couple of months ago. When I am at a red light or stop sign to make a left turn or right, I take off maybe a lil heavy on the gas but the car feels like it is hopping. Like the tires are jumping up and down on the pavement. That is the best way I can explain it. When I straighten out it is smooth as a baby's bottom. It doesn't do it all of the time.
I have had this car almost 10 years and everything is original, shocks and all of that. I am thinking that new shocks will fix the problem. They are the originals that came on the car and I could see that they are leaking a little.
Just wanted opinions. I plan on getting new shocks and springs in a short while but I need to get brakes and rotors first. I am looking at Brembos slotted and haven't really decided on brakes yet. I am doing some research for the best ones.
Anyway guys and gals any input would be appreciated. Thanks much
John
Eagalicious's
1997 Eagle Talon Tsi AWD
K&N FIPK
3rd gen lifters, installed
Apexi Turbo Timer w/harness!!! now to install
Eibach Springs coming soon
3" turbo back with straight pipe.
The muffler was the wrong one
Manual BC
1G BoV
The rest is stock but not for LONG!!
Old 04-18-2006, 12:56 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Bunny hop won't stop!
It could be a really bad cv shaft. You can visually nspect them and see if the boot is broken and if grease is leaking out.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-18-2006, 11:46 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
So it only happens when you get on it around the corner?
Its not the shocks, their job is to absorb the oscillations of the spring. Sounds to me like its just some wheel hop. I believe stiffer springs help and prothane engine mounts should help out a lot too.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-18-2006, 05:35 PM
ez1286's Avatar
He's awd i doubt it's wheel hop, like on a fwd car.
EDIT: It could also be the tie rod ends, they're really cheap and easy to replace.
Old 04-18-2006, 08:43 PM
Thor06's Avatar
Jizzed In My Pants
Oh shit, I thought he was FWD. I dont know then.
