Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-18-2006, 12:49 AM
s14tilo's Avatar
s14tilo s14tilo is offline
Send a message via MSN to s14tilo
Intake and turbo
Is there still an intake on a turbo applied car? I know there is an intake for the turbo, but can you have....a turbo and a cold air intake, or does the turbo take the place of the intake completely?
Old 04-18-2006, 03:56 PM
534BC 534BC is offline
Re: Intake and turbo
A turbo is an added component, It will not really eliminate any components.
An intake can be a manifold, pipe, filter, pipe before filter, opening, cold air, ect.
Old 04-18-2006, 04:01 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Unless you want nasty crap destroying your turbo you had better have some sort of filter before the turbo. Here is how it is setup.
Filter - Turbo - Intercooler - Throttle Body - Intake Manifold - Combustion Chamber
If you don't have a intercooler then just remove it from the equation. However, you need to have an intake.
Old 04-18-2006, 05:27 PM
s14tilo's Avatar
so the filter for the turbo is the only intake?
Old 04-18-2006, 05:44 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Yes, the only air drawn into the engine has to go thru the turbo, if that was your question. Turbos love to suck in cool air taken from the outside of the car. They also like low restriction filters and clever inlet ducting. It's very important to spend some design effort upstream of the turbo as they only like pushing air.
Old 04-18-2006, 05:47 PM
s14tilo's Avatar
Ok, yeah, that answers my question. I am not around a lot of turbo applied cars. Thanks
Old 05-05-2006, 04:19 PM
SaabJohan SaabJohan is offline
Air intake on the turbocharged Audi R8, this intake force air through the filter boxes
One of the two filter boxes which feed the turbos
Engine and one of the two turbochargers
Old 05-08-2006, 02:59 PM
NewyorkKopter's Avatar
NewyorkKopter NewyorkKopter is offline
yea you need the intake because then where's the turbo gonna get the air to force into the engine. As for filtering that air, its a good idea because as Polygon said, you don't want any garbage in your turbo.
Here's a pic of the F40's engine, see how the black air boxes pull air from the outside air intake? the incoming air goes through the filter, then into the turbo where it is spun upward into the intercooler, and then into the engine
Old 05-08-2006, 04:58 PM
s14tilo's Avatar
I know the turbo has an intake, I was just wondering if there was another one. The one that is on N/A cars, but there is not.
Aspirations of an SR....
Old 05-08-2006, 09:23 PM
LoJo LoJo is offline
that is correct case solved lol and with most cars that are daily drivers like the eclipse gsx or gst will usually have an intake within a foot from the actual turbo but as far as an intercooler i thought it was necessary if you had a turbo?
Old 05-09-2006, 11:54 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
no, you often get non-intercooled turbo engines, some of the RB series nissan engines weren't intercooled. lots of industrial/commercial/marine diesel engines run without an intercooler.
Seatbelts Saved My Life
Old 05-10-2006, 02:11 AM
UncleBob UncleBob is offline
AF -Advisor
you don't "need" an intercooler....its just a question of tuning. Many SC don't have intercoolers either. But due to it, you have to lower the boost more than you would otherwise to compensate.
Engine tuning is a very complex issue, and intercoolers are just one aspect of it. Do you HAVE to have an intercooler? Definitely no. Does the turbo HAVE to be close to the intake? Not at all. Study remote turbo mounting if you want to see the extreme of that.
I have seen people run extremely insane boost numbers on pump gas with no intercooler...but they had very well setup tuning. Its all in the tuning. But if nothing else, intercoolers do increase HP WHEN they are sized properly. A badly sized intercooler, or badly placed intercooler can actually be quite counterproductive
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 05-12-2006, 01:08 PM
Most diesel engines today uses intercoolers. An intercooler can give lots of "free" power, and in the case of a diesel they also reduce NOx emissions.
To get a fast response and a godd low speed torque, the exhaust manifold design is very important. The volume between the exhaust ports and the turbine should be small.
Old 05-12-2006, 04:17 PM
yea you don't absolutley have to have an intercooler. But if you don't have one, then you shouldn't really be using high boost pressures because remember that a turbo spins the air, compressing it and then sending it to the engine. And the more you compress air the hotter it gets, this is where an intercooler comes in, a properly sized one will lower the temperature of the air before it reaches the engine and while maintaining the pressure. Thats why most cars running over or near a bar of boost use intercoolers like the F40, whereas cars like the S7 Twin Turbo don't really need intercolers due to them using a relatively low boost pressure. The thing that never ceases to amaze me is how Saleen simply added two turbos running at 5.5 psi and gained nearly 200 hp.
Old 05-15-2006, 04:47 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Cold Air Intake pre turbo does little to nothing. a few degrees pre tubo doesnt make much of a difference when you tur nand cram that air into a small space, which it doenst like.
Closed Thread
