Old 04-18-2006, 12:45 AM
MIKE66G MIKE66G is offline
Bearing Help On '97 Grand Prix
I am having a bearing noise from my right wheel which sounds like a bad wheel bearing.My father-in-law who is a retired mechanic looked at it and he thinks the problem might be an outer bearing on the transaxle where the halfshaft comes in.He says the shaft feels loose up there.Would a bad outer bearing on the transaxle sound the same as a bad wheel bearing?Has anyone replaced this bearing and how would you do it? Any thoughts? Thanks
Old 04-18-2006, 02:08 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Bearing Help On '97 Grand Prix
I don't think there is a bearing there. The right CV shaft connects directly to the differential inside the transmission. If it's a wheel bearing, it will usually get quieter or louder depending on which way the wheel is turned going straight down the highway. It could also be an inner CV bearing going out. Does the car shimmy side to side when you accelerate hard?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 04-18-2006, 03:55 AM
The Loud Humming Noise From The Right Wheel Does Get Quieter If You Move The Wheel Slightly To The Right.the Noise Is Not Affecting The Way The Car Drives Or Handles Yet.
Old 04-18-2006, 06:06 AM
wlkjr's Avatar
wlkjr wlkjr is offline
That's the same thing mine was doing and I replaced both wheel hubs and it fixed the problem.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 04-18-2006, 08:37 AM
Yep, thats a wheel bearing.. Expect it to be over $100 easy..
Old 04-18-2006, 04:14 PM
radeck radeck is offline
just DO NOT get cheap wheel hubs, you gonna regret it...especially those from autozone or advance in white boxes DYNAPAK I think. I did fine with BCA and they are about $150 each... unless you want to go with OEM
Old 04-18-2006, 04:23 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I agree.
The BCA - Federal Mogul are good Hub/Bearings. IMO better than AC Delco.
Timeslip 08/12/06
AF Community Guidelines
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
There is a bushig in the extension housing of the trans where the CV axle goes in that can get worn and cause a sloppy fit and noise. Your problem sounds more like a bad hub than a transaxle bushing to me though.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
