Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-17-2006, 11:09 PM
quicksand quicksand is offline
funny idle
i took off the throttle assembly which has the idle speed control valve and tps i cleaned it very good sprayed carb cleaner through the bottom of the isc where the air usually come through. the car runs smooth when pressing gas and better acceration but the idle is crazy now. i dont know if i did something wrong or maybe the idle spped control was already bad. was i not suppose to clean it like that?
Old 04-18-2006, 06:25 PM
Soilent Green Soilent Green is offline
Re: funny idle
What do you mean crazy?
It might just be a bad Throttle Position Sensor or that some crap dripped back down your IAC hole upon reinstall.
I say give it a good spray down that hole again, but with the engine idling this time, and use the TB pulley to keep the car from stalling. Maybe it's just that, or not, but you'll be sure.
My first TB cleaning ended up not changing much because it was SO filthy not even half the job was properly done so I repeated idle treatments every weekend until most of my problems were gone. Except the shaky RPM needle at idle that I'll need to have a look into next.
Old 04-18-2006, 10:33 PM
Re: funny idle
im getting a code 51 Switch Condition Signal. im not sure what that means though thanks
Old 04-21-2006, 06:22 PM
Re: funny idle
Google that code, including the zeros if there was any.
Like right now my CEL is on with code P0446
Google the exact code and come back here with the results. What year is your car I have a Haynes for 97-01 camry.
Old 04-21-2006, 09:25 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: funny idle
In a 92-96 Haynes manual it says the A/C switch/amplifier circuit, neutral start switch, THROTTLE POSITION SENSOR, and ECM are the likely trouble areas for code 51. You know where to start.
