Old 04-17-2006, 09:58 PM
doodlewop's Avatar
doodlewop doodlewop is offline
CRX Dash Fit In A 91 Civic Si Hatch?
Hey what's up everyone I ran across a CRX dash and I wanted to see if it would fit my 91 Civic Si. I was wondering if anyone on here has done that swap and if it will actually work. Thanks alot
Jason
Old 04-18-2006, 07:31 AM
Hybrid1990crx's Avatar
Re: CRX Dash Fit In A 91 Civic Si Hatch?
yes it will fit. if the crx dash is also from a 90-91 it'll bolt right in, if its from a 88-89 you'll have some wiring to do.
Old 04-18-2006, 08:01 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
It will fit. I have done it to my std hatch and everything bolted right up.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 04-18-2006, 08:22 AM
doodlewop's Avatar
Yea Im pretty sure it's within the same years as mine. I'll make sure though. The only thing that puzzled me was the electronic climate controls, I'm not sure how that will work out, but I'm sure I'll figure something out. Anyways thanks guys for the help.
Jason
Old 04-18-2006, 08:30 AM
doodlewop's Avatar
Here's some pics. Sorry about the quality.
Its a 91 Si w/ a B18c1 Swap
Old 04-18-2006, 08:32 AM
doodlewop's Avatar
Old 04-18-2006, 08:34 AM
doodlewop's Avatar
Im an idiot, this ones better
Old 04-18-2006, 01:31 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Just use your climate controls, unless you really want the push button..then you got alot of work ahead of you.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-18-2006, 05:56 PM
dagoEF's Avatar
dagoEF dagoEF is offline
You'll only have to re-wire if you are swapping the cluster, ie 88-89 to 90-91 or vise versa. If you are using your old cluster you'll just have to modify the gauge cluster mounting brackets and use the cluster hood appropriate to the cluster. I put a 88-89 CRX dash (I was told it was a 90, found out the hard way) into my 90 hatch and only ran into probs with the brackets (trimmed) and cluster hood (had to get a 90) with mine.
Old 04-19-2006, 09:23 AM
doodlewop's Avatar
Yea I was gonna use my wiring anyways, because I'm not sure if it's complete or not. I have the cluster hood and pretty much everything else. I compared it to another 90 91 civic dash and it looked the same as far as the brackets go, when I start tearin it apart I'll know lol. Yea I'm just gonna use my climate controls I didnt think about that. I also ended up getting a rear disc conversion and a front GSR brake conversion so my works gonna be cut out for me for a while lol. Thanks for the help
Jason
