Old 04-17-2006, 09:24 PM
jmglucky jmglucky is offline
2000 oldsmobile intrique heating problem 3.5
Actually, I'm not convinced it's a heating problem. The problem is that water runs off the resevoir and the engine isnt even hot according to the temperature gage. I replaced the termostate, added 50/50 coolant and air bled the system thru air bleed valve located on radiator. fans work okay. Can anybody direct me cause I'm just about to give up and take it to a Certified Mechanic. Oh, I usually work on my vehicles and usually am pretty successfull exept for now. Of course, once it throw out the water, then it will overheat if not re-filled.
Old 04-18-2006, 04:44 PM
panzer dragoon panzer dragoon is offline
Re: 2000 oldsmobile intrique heating problem 3.5
there is an air bleed valve on the engine also.
Old 04-24-2006, 07:33 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
I'd like to know where the air bleed valve on the engine is........ I've never been able to find it.
Old 04-26-2006, 06:56 PM
I never looked for it and dont know where it's at. I just dropped the car off with a mechanic friend to flush the system out and take care of it. Sorry
Old 04-26-2006, 09:46 PM
I sent you an Alldata diagram of where the bleed valve is about a year ago. You're right in that it's hard to find. From the diagram it looked just like a regular bolt. You said before that the GM manual had a poor diagram but talked about the bleed bolt.
later edit:
http://www.automotiveforums.com/vbul...ighlight=bleed
Check your mail for that diagram. I don't have Alldata anymore, it's my Dad's turn to pay. (I am relying on this forum without my AllData crutch)
