Old 04-17-2006, 08:10 PM
typerx7 typerx7 is offline
98 z24 traction control
ive got a 98 cav z24 and at times the traction control light comes on that says the traction control is off. Whenever the light is on, the car will shift very rough. is there anything i can do besides replace the tranny again?
Old 04-17-2006, 08:55 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: 98 z24 traction control
Is it automatic or 5-Speed?
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 04-17-2006, 10:42 PM
its a auto
Old 04-19-2006, 12:36 AM
spaceman88 spaceman88 is offline
theres a couple things you can do..... get an ecu that doesnt have traction control programmed into it.... get a racing transmission..... get a shift kit from your local shop which is alot cheaper then replacing the transmission, because they are referbushing the one you have..... get a manual car...... make sure your crank case and gears are alined correctly, and stop beating the crap out of the car....
Old 04-19-2006, 09:11 AM
well im not going to put any racing tech into this. this car is for driving to work and back and for no reason would i beat the crap out of it. this thing is nothing compared to my 94 civic gsr turbo. would changing the ecu really trick the car into thinking it has no traction control? is there any type ofrewiring i could do, such as splice a wire for the TC with a switch then remapping the ecu when it is off? ecu can be programmed any which way you like given certain perameters. i dont know anything about chevys computer systems.
Old 04-19-2006, 09:27 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
is it even possible for a 5 speed to have traction control??
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 04-19-2006, 10:31 AM
Yeah i'm pretty sure it is, just not as effective as auto traction control. Ive seen it, it kind of sucks, you cant burnout at all even if u dump the clutch it will lurch then grab and bog down lol.
