Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 04-17-2006, 08:05 PM
wakeboard_dude5 wakeboard_dude5 is offline
Send a message via AIM to wakeboard_dude5
Coil-over help!!
Allright so here's the deal. I bought some used skunkworks (skunk2 before the legal crap started) coilovers and i don't know which go in the front and which go in back. They look almost identical except for the numbers stamped on it. Two of them say "0800.2.50.008" and two say "0800.2.50.010". Anyone know which go where? or can someone atleast tell me what these numbers mean?
1993 civic EX coup auto SOLD! but i'll miss her
1996 Civic CX w/ B18c1 swap, small bolt on's, 2000 front end
Old 04-17-2006, 09:09 PM
iCivic iCivic is offline
Re: Coil-over help!!
measure the height? smaller ones go in the front, plus i'm not sure about yours but usually the springs for the front are a little thicker
Old 04-17-2006, 09:59 PM
they're the same height, couldn't afford true coil-overs i'll check into that thicker thing, can't remember if they vary but i never looked into that type of thing.
Old 04-17-2006, 10:49 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
8 is the fronts
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 04-18-2006, 01:04 AM
When i took a closer look i found that the 10's were a little thicker than the 8's so would that mean the thinner are up front kicker1? or do i put the thicker ones up front and the thinner ones in back? it would make sense that the thicker would be a little more stiff for up front
Old 04-18-2006, 04:08 PM
i've always known the front to be thicker due to the load of the car being put on the front being as it's front wheel, but if they're the same height i'm sure they're work either way, i'd put the thick ones on the front
Old 04-18-2006, 07:35 PM
I don't know. Originally you said that both are the same so I was just helping you make up your mind about which to put up front. And if one is a little thicker, put those up front.
2000 BMW 323IT
1954 Ford F100
Old 04-18-2006, 09:23 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
With the numbers you gave, I'd deem is safe to say the last number reefers to the spring rates, thus the 010 would be 10kg and 008 would be 8kg. My Tein coilovers have similar type numbers on the springs.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-18-2006, 09:31 PM
lol my Sprint springs just came in and they look similar also, but one is thicker, so i'm puttin the thicker in front assuming...
now i think the part witht he wider gap in the spring goes on the bottom? can anyone confirm that?
Old 04-18-2006, 10:35 PM
that is correct, your stock springs should be the same way too, just look at those
2000 BMW 323IT
1954 Ford F100
Old 04-19-2006, 12:58 AM
I know this is a newb thing to ask, but i just got off work and too tired to search it but... whats the difference between say 8kg and 10kg? and why would they go in front/back? i havn't really researched too in depth about spring rates and all that. OR!!! if someone has a great thread or site that explains it all i would love to see it. thanks
Old 04-19-2006, 05:19 PM
i don't know anything about that number shit, but i'm assuming as it's in kg that it's either the weight of the springs or the load bearing weight in some form
Old 04-19-2006, 07:32 PM
read this thread...
2000 BMW 323IT
1954 Ford F100
Old 04-20-2006, 09:53 PM
Cali Guy
It's the weight that's required to make the spring compress. 10kgf/mm is equal to 559lbs./ft of force required to make the spring compress. An 8kg is equal to 448lbs. of force. Google "spring rates" and you'll get a better understanding. On any 5th or 6th gen Civic ('92-'00) you always want the stiffer spring up front as so the car won't sag lopsided from the engine weight at the front. Also the suspension is built around a stiffer front from the factory. Just as an FYI, Skunk2 (and Skunkworks) sleeved coilovers like you have came for Civic mad with a 500lbs. front and 400lbs. rear spring rates, so roughly 10kg and 8kg respectively minus about 50lbs which should really make them 9 and 7kg.
hessemer69 on AIM
Old 04-21-2006, 11:10 PM
this shit is so dumb, i went to put on my new springs and struts, the Koni struts have a finer thread so the old bolt didn't fit on..
that's like the biggest scam to screm someone over ever lol
