Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-17-2006, 06:28 PM
Rajan Rajan is offline
Saturn 99 SL1 ECT check and replacement
What does ECT stand for ? I need help in locating and checking ECT in Saturn 1999 SL1.
Please help me in doing that.
Thanks.
Old 04-18-2006, 12:07 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: Saturn 99 SL1 ECT check and replacement
electronic coolant temperature sensor.
it is located on the drivers side of the head just barely above the trans housing. now checking it is another thing, are you getting a temperature reading? is it showing hot when you first start up cold? if you were told its bad but your temperature gauge seems to work normal, then there isnt much more of checking it. and to check resistance on it is practically useless, so replacement is the best option as long as you know its bad. saturns typically go through these things, mainly the stock plastic ones. replacement should be brass, dont get another plastic one.
with what is involved in removing it, replacement once removed is the best option, because otherwise you get to drain the coolant down to pull this little thing out. replacement is quick so you dont loose much coolant.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
