Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 04-17-2006, 06:16 PM
nuwt's Avatar
nuwt nuwt is offline
Send a message via ICQ to nuwt
I did a piston soak
I did a piston soak with MMO and my 99 Neon Sort quit smoking and gained all kinds of power. Will drive it alil longer to see if it helped oil consumption. I have heard of doing this to Saturns for bad oil consumption and it would help, So I tried it on my Neon and it did help! It has alot more power now.
Laugh all you want!!!! I have NO Payments!!!
Old 04-17-2006, 08:27 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: I did a piston soak
Seafoam does the same thing and people swear by it. I have yet to try it though!
Old 04-18-2006, 12:19 AM
TEXSRT4 TEXSRT4 is offline
MMO is awesome!!! cures everything
Old 04-18-2006, 12:22 AM
sheetmagnet sheetmagnet is offline
Send a message via Yahoo to sheetmagnet
Okay someone please explain the product to me
Old 04-18-2006, 01:27 AM
maykelcj's Avatar
maykelcj maykelcj is offline
Originally Posted by nuwt
I did a piston soak with MMO .
??????????????? illutrate:
12:1 all motor neon, sold
got me a CRX HF and put a DOHC ZC on it.
Old 04-18-2006, 07:25 AM
Marvel Mystery Oil!
Old 04-18-2006, 07:39 PM
nuwt's Avatar
Originally Posted by das2123
Marvel Mystery Oil!
I will try to find the link where I first learned about hte MMO soak
and here it is, http://www.saturnfans.com/forums/sho...MO+piston+soak
it is on another forum with a difeerent vehicle, but it is the same procedure. and it has help 2 of my over 100,000 mile vehicles, one with close to 300,000. It didn't stop the oil burning on the 200 plus, but it did make it run smother and Seafoam will do the same from what I have heard. i buy the MMO from Dollar general for $2.00 a quart, but other stores carry it for about the same price as Seafoam here is close to $5.00
Old 04-19-2006, 05:06 AM
Marvel Mystery Oil!
Ah, gotcha. I know some people that used to mix it with their gas, but I didn't know that stuff was that reliable. Hmm.
Old 04-19-2006, 08:03 AM
To do the piston soak with MMO, do you have to disassemble anything? With Seafoam, you use the brake booster vacuum line to get into the engine.
Old 04-19-2006, 03:37 PM
nuwt's Avatar
With my S 10 i poured it down the carb. On the Neon I removed spark plugs and poured it in the hole. You can remove a vacumn line that will pull it into the piston/Gas chamber also. You can pour it through the throttle body if you use a funnel and hose and let it be sucked in that way also. You can do a search from the link I provided for MMO piston soak and find alot of information also. That is where I got most of mine.
Old 04-19-2006, 03:43 PM
Cool, thanks for the info!
