Running Hot
Hi, I have slight problem I have a 94 cadillac deville concours with a 4.6 The problem that i am having is it keeps running hot. I have put a new thermostat, water pump, radiator and cap,and both fans come on but it keeps running hot I am finding it hard to believe that it could be the heads or head gasket because there is no water in the oil and when I crank the car it does smoke at all. Does any one have any ideas Thankx.
Re: Running Hot
What do you define as running hot? What temperature is the engine running at? The 4.6l Northstar routinely runs up to 240 degrees.
Re: Running Hot
Two things..
First, what do you call hot? Second, AFAIK the '94 Devilles were 4.9s not 4.6 Northstars. |
Re: Running Hot
Re: Running Hot
Re: Running Hot
I've never heard of anything like that. You may have a leak somewhere causing problems, the 4.6 uses a sealed coolant system and a leak would cause the water to begin boiling, causing all sorts of problems.
Also, the '94 DeVille could be had with either the 4.9 or the 4.6. |
Re: Running Hot
Re: Running Hot
I'd suggest flushing the coolant. There could be some sort of blockage in the system somewhere causing the coolant to back up in the system.
Re: Running Hot
There is a purge line that runs from the surge tank down to another fitting near the water pump and below the throttle body. Verify that it is not clogged.
