Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-17-2006, 05:22 PM
tdm1971 tdm1971 is offline
94 Camry cracked coolant reservoir
I just noticed a small crack in the top of my coolant reservoir next to where the clamp that hold it in place is located. The crack is small maybe about half the size of a dime.
I put some duck tape over it for now. How will this affect the cooling system and what damage could be caused if I waited to get this fixed? Also, the best price I have found for a coolant reservoir is $115 (4 cylinder). Does this price seem high?
Any help, suggestions, are appreciated.
Old 04-17-2006, 07:43 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 94 Camry cracked coolant reservoir
Yes. Get a used one from these guys :http://www.taprecycling.com/ It's a huge Toyota parts recycler in California. I wouldn't put a big priority on it but, you should change it.
Old 04-17-2006, 08:29 PM
Thank you for the reply. My main concern would be air or dirt getting into system or further deterioration of reservoir causing particles to fall into the radiator. I will check the site and see if I can't order one to be shipped to Maryland. I noticed the crack yesterday. Any idea of how many miles, or days I can hold out with very light driving?
Old 04-17-2006, 08:51 PM
JOET/CAMRY JOET/CAMRY is offline
Lightbulb Re: 94 Camry cracked coolant reservoir
Hello TDM1971,
You could just put an epoxy patch over the crack on your coolant overflow container to patch it up and to prevent the crack from spreading. Cover the area of the crack and feather out the epoxy around the edges of the patch. You can use a piece of screen over the crack if it's too big or just for added strength. it's alot cheaper than spending $115.00 on a new reservoir.
I bought an epoxy at a plumbing store years ago called A + B fast epoxy paste (5 minute bonding action) used for industrial use. I patched a hole in a gas tank and fixed a blown head gasket on my old 1983 Nissan pickup. .. The engine was pissing out coolant (around head gasket) when I shut it off so I cleaned the area where the leak was with degreaser and patched the hole with the epoxy. the patch held up for over a year. It's some good stuff. I know that it was a half ass repair but it did the job. the truck wasn't worth replacing the head gasket. It had a rotted frame. Take care.
Regards,
JOET/CAMRY
Old 04-17-2006, 09:43 PM
Joe:
Thanks for the advice. I have duct tape on it now. I'll check out the epoxy, never thought about that. Looking for something from a salvage place as that will be my best bet in the long run.
Old 04-17-2006, 10:40 PM
Originally Posted by tdm1971
Joe:
Your welcome. Good luck.
JOET/CAMRY
Old 04-18-2006, 08:07 AM
GSS123 GSS123 is offline
I've had good luck fixing coolant reservoirs with JB Weld epoxy that you can buy at automotive stores or Wally world.
Old 04-18-2006, 08:50 AM
lenjack lenjack is offline
I've seen new ones on Ebay for $40.
Old 04-18-2006, 08:06 PM
AccordCodger AccordCodger is offline
That really won't do any good at all. As soon as the motor warms up, the pressure in the cooling system will more than defeat a little duct tape.
Old 05-05-2006, 09:33 AM
xiong xiong is offline
sorry
Old 05-05-2006, 09:36 AM
sorry
Old 05-05-2006, 05:35 PM
there is no pressure in the coolant reservoir.
Old 05-05-2006, 07:32 PM
True - my error.
tdm1971 - get one from a junkyard. My guess is around 5 bucks.
