Calling all gearheads. I've got a 2002 Venture that suddenly won't start. This past weekend, I shut it off after backing out of the garage, and it took six or seven tries to start (just turns over). Once I got it started, it ran good but sounded like it was pinging (real light sound, not like a normal ping). I did have a check engine light after it ran a while.
We stopped to eat three hours down the road, and it wouldn't start again. I ran the battery down trying to start it. Towed it to a shop, and they put a computer on it. No code due to low battery. Checked spark, they said it looked weak. Checked the fuel pressure @ ~50 lbs. After messing with it for a while they got it to start. Computer check said it 'might be' the crank sensor. Got one sent in, but they couldn't do it that day. During troubleshooting, we killed it, and it wouldn't start again. After messing with it for hours, got it running again. From there to final destination, it shuddered on almost every uphill it took (sorta acted like bad gas). Got check engine (immediately on start). ANYWAY, after putting the new crank sensor on, it still won't start. Just turns over... Any suggestions? |
Re: 2002 turns over but won't start
I would suggest getting the code(s) out of it before the battery is drained again. That should help identify the problem. Take Care,
Greg A. 2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010) 1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010) |
Thanks for the idea, but too late. I ran the battery down again trying to crank it after trying a few other things...
Maybe it's your spark plugs how much miles do you got on it. That shudder you felt going uphill could have been a misfire under load.
Thanks for the input. Later! Peace, Blane |
